Compression Test
What do I need to unplug fuel related when I do a compression test? So the fuel doesn't spray.
My car is burning about 2 quarts of oil every 3.5k miles. Going to do a compression test. Eitherway, would this be head gasket or piston rings?
Pull all the wires, and pull each plug one at a time, Hold the throttle down when you are doing it. If your burning oil chances are its the piston rings or valve seals. A head gasket you would see milky oil, and or oil in your coolant.
There's plenty of youtube vids and DIY's if you do a quick search.
As stated, a compression test won't necessarily reveal your problem. Your compression rings could be good and still burn oil.
http://autos.yahoo.com/maintain/repa...ques056_1.html
I have not had a chance to do a comp test on it yet, might do so this weekend.
ewilliams1990
Jun 28, 2014 03:44 AM
iBrandon
Jul 31, 2006 08:03 AM
