Compression Test Numbers
Old Oct 2, 2007 | 03:55 PM
Cheez-It's Avatar
Default Compression Test Numbers
My b18b has been smoking a bit in the higher RPM ranges and when i decelerate in gear so i did a compression test and they where all in the 180-190 range. could this possibly be my rings? are there any other tests i can perform that will help me determine the cause?
Old Oct 2, 2007 | 03:56 PM
Exeed's Avatar
Default Re: Compression Test Numbers (Cheez-It)
Isn't that where they're supposed to be? I'd check your valve seals.
Old Oct 2, 2007 | 03:57 PM
JasonST's Avatar
Yes, do a leakdown test, u basically do the same thing as the comrpression test but just put about a teaspoon of oil in each of the cylinders, and if the compression goes up, then u know it's ur rings.
Woot for my 1000th post
Old Oct 2, 2007 | 07:27 PM
Cheez-It's Avatar
Default Re: Compression Test Numbers (JasonST)
but when i used the search they said dropping in a teaspoon of oil through the spark plug hole would do no good because the LS pistons have such big craters in the middle that the oil would never make it to the outer skirts of the piston.
humboldt_skim
May 31, 2008 08:18 AM
sinister357
Aug 25, 2007 10:05 PM
vinuneuro
Apr 25, 2007 10:13 AM
arejaygsx
Dec 19, 2006 06:32 PM
EF8_SiR
Jul 20, 2003 10:24 PM
