2002 honda accord dash light issue
Old Aug 15, 2011 | 05:23 PM
ThatOne02Accord's Avatar
Default 2002 honda accord dash light issue
Hi, I bought a 2002 Honda Accord SE Automatic. It has the 2.3L VTEC engine. I haven't had any problems with the car, until recently.
When I punch the gas(Full throttle) and it shifts at redline, the Battery, brake, brake lamp, and all the door open lights along with the truck open light come on... If I let off the gas and drive normal, they will stay on but when I punch the gas again all the lights that came on, will go back to normal but will flash every 7 seconds or so. It acts like all the doors are open and the truck is popped open, along with the battery light and brake light on.
If the lights come on, I can shut the car off and start it again and it will be back to normal.
I had Autozone plug into to car to see if any codes came up, but they couldn't find any. Wondering what the problem could be. The car runs great, even when the problem occurs.
Old Aug 15, 2011 | 06:35 PM
phootbag's Avatar
Default Re: 2002 honda accord dash light issue
Stop driving like a maniac.
Is the alternator belt tight?
Old Aug 15, 2011 | 09:28 PM
My voltage is 14.25 from the alt. Belt is tight and doesn't squeal. It happens when driving normal, but will do it more often when at full throttle.
Old Aug 16, 2011 | 08:16 PM
jdowen2's Avatar
loose or corroded ground connection.?
Old Aug 17, 2011 | 05:01 PM
My battery terminals were corroded, I cleaned them and left the terminals off the battery, so that it would reset the ecu. Still having the same issues.
It's possible it could be a loose wire, or sensor going bad, but cannot pin-point why it happens when punching the gas to get up to speed on the entrance ramp to the interstate.
Kinda wish it would throw up a code when it happens but it doesn't. I hate to take it to the honda dealership and they over charge me, when it could be something simple.
The car runs great, even when the lights show up.
Also my SRS light is on, someone said it could be something unplugged under the seat.
Old Dec 18, 2011 | 12:04 PM
evilcivilian's Avatar
I have the exact same problem. The lights goes on when im driving i already replaced alternator as suggested by a mechanic but it did not fix the issue. Have you found a fix for your issue yet?
Old Dec 20, 2011 | 04:44 AM
Before I said, it happens whenever I punch the gas...that's not true. It happens randomly, while just driving normal or at idle....
I never really found the problem. Not sure what it could be.
Someone did tell me that it was a common problem on all the hondas he drove and that it was something behind the dash. He said it doesn't affect anything, so if it doesn't bother you, don't worry about it....
I did install a Cold Air Intake system to the 2.3L 02 Accord and it made the car a little faster, and I got an extra 1mpg!!! Still have the same issue.
Not sure if anyone on this forum will know the solution.
Old Jan 28, 2017 | 09:50 AM
Sullie's Avatar
I am having the same problem with my 2002 honda accord lx .my battery was only 6 months old. The kid at orielys ssid it was bad wouldn't hold a charge so i bought a new battery. Had the altenator tested amd it was fine.the car dashlights are still going on ONLY when i accelerate.
i have a. Code reader and it is not showing any codes. " codes found 0" i do not want to take it to Honda cuz i know they will way over charge me. Can u help me and tell me what It possibly cud haor Wat i shud do nxt. And wud it be bad if i continue to drive it with all the warning lights on (battery light ,all doors op en, trunck, srs, etc.) cuz ineed to get to work i am a single mom wit no brothers to help me so i am in serious need of advice
Old Jan 28, 2017 | 09:56 AM
Sullie's Avatar
I am having the same problem with my 2002 honda accord lx .my battery was only 6 months old. The guy at O'reilys said it was bad wouldn't hold a charge So like an idiot i bought a new battery. I Had the altenator tested amd it was fine.the car dashlights are still going on ONLY when i accelerate.
i have a. Code reader and it is not showing any codes. " codes found 0" i do not want to take it to Honda cuz i know they will way over charge me. Can u help me and tell me what It possibly cud be.or Wat i shud do nxt. And wud it be bad if i continue to drive it with all the warning lights on (battery light ,all doors op en, trunck, srs, etc.) cuz i need to get to work i am a single mom , and i have no brothers to help me. so i am in serious need of advice.
Old Jan 28, 2017 | 08:02 PM
holmesnmanny's Avatar
In situations like this the best thing to do is to take it to an electrical specialist.
Old May 25, 2019 | 06:01 AM
Gary DuJack's Avatar
Old May 25, 2019 | 06:02 AM
I just started having the same issue. Did it ever stop, or did you find out what it was
Old May 25, 2019 | 12:38 PM
MAD_MIKE's Avatar
MM Gruppe B
Check ground terminal G-401. I *think* on the 98-02s it is located on the center console bracing where about where your would be.
It's a big wad of wires that probably get knocked loose.
chany
Mar 1, 2015 10:50 AM
chany
Feb 27, 2015 02:19 AM
December2712
Jul 24, 2013 09:46 PM
leflore
Jan 13, 2013 06:40 PM
katherineborell
Nov 8, 2009 09:04 AM
