have to press on gas while turning ignition to get car to start
Old Aug 14, 2011 | 02:53 PM
the soL that could's Avatar
Icon6 have to press on gas while turning ignition to get car to start
why? when i turn the key, it starts up and shuts down... i have no idea what the person (who owned the vehicle before me) did... SRS light is on and WILL not go off even after the reset method stickied.
Old Aug 14, 2011 | 03:05 PM
Former User's Avatar
Default Re: have to press on gas while turning ignition to get car to start
Car/engine/mods? CEL codes?
Old Aug 14, 2011 | 03:20 PM
bone stock... happened to the USDM d15b that was in there when i purchased... i swapped a JDM d15b vtec yesterday and still encountering same problem... no mods, no CELS, nada...
Old Aug 14, 2011 | 03:48 PM
BallinDA256's Avatar
Mine has the same issue but after I get it started if it drops below 1k rpm's it dies unless I give it gas. bump for a solution.
Edit: I also have a bone stock d15b7 no mods or cel
Old Aug 14, 2011 | 04:32 PM
vitamin_c95's Avatar
mine did that in 07. I got lucky and replaced my pcv, prob went away
Old Aug 14, 2011 | 04:41 PM
Car? ECU?
Are you able to keep the engine running after it starts? If so, does it run poorly? Any CEL codes? Are the plug wires installed in the correct firing order?
Old Aug 14, 2011 | 04:52 PM
Icon6 Re: have to press on gas while turning ignition to get car to start
Car? ECU?
[/IMG]
car 94 honda (eg) sedan dx
ECU: p06
yes... after i get it started, it runs like a dream. idles smooth... does not run poorly, but does feel weird around/between 30-50mph. not sure if it is engine related because it happened in the usdm d15b7 and the jdm d15b.
changed the fuel filter/plugs... i got a cap and rotor on the way. i am thinking, fuel pressure regulator/fuel pump... going to throw some injector cleaner into the gas tank tomorrow. well, main relay primes the fuel pump every time... i have no idea.
Old Aug 14, 2011 | 05:06 PM
exb18c1's Avatar
What do you mean by running weird at? Try to give us as much info as you can.
Old Aug 14, 2011 | 05:21 PM
might be suspension/wheel/steering etc... related i just got the vehicle, so i am still in the process of troubleshooting. do not think it is related to the starting issues...
Old Aug 14, 2011 | 06:58 PM
Does the CEL work?
So it's just a cold start problem, right? If so, try cleaning and adjusting the FITV. Not absolutely sure, but I think the JDM d15b vtec may be better suited for a P28 ECU.
Old Aug 14, 2011 | 10:49 PM
Does the CEL work?
how do i check if the CEL works? the light DOES come on when i turn the key... when i switch ECU from the p06 to a p08, the CEL lights up/throws a code (however, i did not run the code and ran the p06 instead)...
maybe this will help:
1) i have to "prime" push the gas pedal a couple of times, prior to starting it.
2) i have to "maneuver" the key in order for the dashboard to light up.
i dumped a bottle of Techron in there...
i will take your word for it Ron and run a p28/automatic ...
Old Aug 15, 2011 | 06:37 AM
exb18c1's Avatar
By the way ,to prime you just have to put the key on.In fuel injection system ,when you press the accelerator pedal to the floor you are doing the opposite.You cut the fuel.It's called the "clearflood mode".What you can try is after cranking the motor few times (without pedal depressed),remove the spark plug and see if it is wet.We will take it from there.Maybe the ECU commands way too long(rich) of basic injection time.
Old Aug 15, 2011 | 11:31 AM
no... i replaced them. the plugs i have are like 3 days old. NGK v-power.
Old Aug 15, 2011 | 01:52 PM
exb18c1's Avatar
It doesn't matter.You can still see if the are getting wet or no!
Old Aug 15, 2011 | 02:53 PM
sorry... i was unclear... i CHECKED them and they are NOT WET.
Old Aug 15, 2011 | 03:14 PM
exb18c1's Avatar
Let's start from the begining! From what I understood the car won't start at all unless you push the pedal to the floor,right?
Does it do it every time?
Old Aug 15, 2011 | 03:53 PM
no... the vehicle is old... i have to hold the key in a certain spot to get the dash to light up also. not sure if they are related...
Old Nov 10, 2011 | 01:12 PM
pedropicapiedra's Avatar
I have the same problem...honda civic 99 lx ...check and clean air intake valve, changed spark plug wires. Checked codes...game me oxygen sensor heater and cathalitic converter on exhaust manifold.
check exaust manifold, found crack and welded..tok off and put it back...reuse gaskets and aplied gasket paste to avoid leak.
After i clean up my air intake valve body, my throttle is smooth.
I am trying to clean up my oxygen sensor...270,000 km..by appling heat and blow with compressed air ..and leaving overnight immesed in gasoline.
Have not yet tested my volage and resistance on the oxygen sensor.
reset CEL check engine light..BUT>>STILL HAVING THE SAME PROBLEM
Old Dec 13, 2013 | 01:54 PM
honda-sara's Avatar
hi guys I just bought a 95 Honda accord. It will only start when I push on the gas pedal. Once its on it runs great but if it drops under1 rpm it dies. I also cant drive it for to long because the cat converter over heats. Before I bought the car it sat in a women's driveway for 8 months.
Old Oct 3, 2021 | 07:19 PM
honderman's Avatar
I have this same issue did you ever figure it out??
Old Aug 4, 2022 | 02:35 AM
38special!'s Avatar
I would like to say i had the same issue every time my ignition coil got weak. it will usually fail soon after . Ive had the issue at least 5 times in different vehicles.. the problem is usually caused by bad ground from head to front grill area. i always have a backup coil now but i get cheap ebay ones and two distributors so i can switch them out fast. of course they all had distributors, 2004 civics and newer do not have distributors , each plug has a coil .
thunderfck
Mar 4, 2013 04:19 PM
DAVE15401
14
Sep 29, 2007 03:20 PM
Cryptopsy
Aug 31, 2006 08:37 AM
Sukii
Mar 28, 2006 08:45 PM
adam
Nov 13, 2001 06:45 PM
