Engine not starting..help needed
Old Mar 27, 2006 | 04:59 PM
Sukii's Avatar
Default Engine not starting..help needed
Alright guys, heres the deal:
Acura Integra GSR: 2000
Miles: 59xxx
CEL light on, Maintenance Required light on
Set up: T1R 2.5" catback exhaust, JDM 4-1 Header, SMSP Cat
Last time i drove the car was on Friday 3-23. Today i tried to start the car and now it isn't starting. Before this happened, the car was runnig perfeectly fine, no signs of any sort of problems going on with the motor. I am a bit low on gas however not to the point where the gas light has come on. Thinking that it might be low on gas, i went and got some fuel and put it in, the car still does not start. When i try to start it (meaning i turn the key all the way and hold it until it starts like i normally do) there is only one tick. Every so often, it would sound like its trying to turn over, but not able to ( meaning it starts to turn but then stops being it seems like its stuck or something) Now i do have a CEL (code 67). The motor has always been running fine even with the CEL light on. Now the maintenance required light has came on recently, maybe about two weeks ago because my car is almost due for its 60k service. I dont know if these two things have any thing to do with it but I dont know wat the problem is and I need some assistance. Please help
Modified by Sukii at 12:28 AM 3/28/2006
Old Mar 27, 2006 | 05:12 PM
gixer00's Avatar
CHECK TO SEE IF YOUR GETTING FUEL OR SPARK AND LET US KNO WHAT HAPPENS
Old Mar 27, 2006 | 05:26 PM
PY TYPE R 483's Avatar
Default Re: (gixer00)
random shot, but is your starter going bad, and how is your battery?
Old Mar 27, 2006 | 05:30 PM
Sukii's Avatar
Default Re: (PY TYPE R 483)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PY TYPE R 483 &raquo;</TD></TR><TR><TD CLASS="quote">random shot, but is your starter going bad, and how is your battery?</TD></TR></TABLE>
Everything should be working fine, since I have never had a problem startign the car at all until now after i haven't driven it for 3 days
Old Mar 27, 2006 | 06:06 PM
JFG Kevin's Avatar
I was guessin that too. Make sure your battery isn't bad. try jumping the car. Most likely it's not your start.
Old Mar 27, 2006 | 10:03 PM
Sukii's Avatar
Default Re: (aznstyler119)
Hmmm, any more opinions, i'd like to get this fixed asap
Old Mar 27, 2006 | 10:12 PM
integra3586's Avatar
Default Re: (Sukii)
my guess is the battery. if you left it sitting since 3-3-06, if the parasitic drain was enough it would kill the battery. happens pretty easy on an old battery
Old Mar 27, 2006 | 11:29 PM
Sukii's Avatar
Default Re: (B18B-SC)
oops, sorry i mean 3-23, so i really only let it sit 3 days ago
Old Mar 28, 2006 | 01:01 AM
andrew714's Avatar
Default Re: (Sukii)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sukii &raquo;</TD></TR><TR><TD CLASS="quote">Hmmm, any more opinions, i'd like to get this fixed asap
if you want answers, you are going to have to give some details of what is happening when you are trying to start it. you can check to see if it is getting fuse by removing the bolt on top of the fuel regulator and turning the key over to see if gasoline is coming out. to check to see if you are getting any spark; first remove the spark plug wire and attach it to a working sparkplug, hold it about 1/4 inch away from a metal that is grounded, finally have someone try to start it and see if you are getting spark
Old Mar 28, 2006 | 02:29 PM
Default Re: (andrew714)
try push starting it. that will rule out ignition, fuel, everything else, except the starter system and battery
Old Mar 28, 2006 | 08:45 PM
stumpyf4's Avatar
Default Re: (Sukii)
Try jump starting like someone said below. If it starts your battery is most likely weak. Buy a new one or test the old one at Autozone.
BxEF
18
Aug 27, 2008 09:50 PM
nemeii
23
Aug 10, 2008 03:10 PM
patrick_yi_82
Aug 4, 2006 10:13 AM
mhng
Apr 23, 2005 06:44 AM
dilow
Sep 1, 2001 09:31 AM
