tips on buying a used engine?
Old Aug 9, 2011 | 08:46 AM
G3teg96's Avatar
Default tips on buying a used engine?
i'm looking to do an LS vtec in my teg, but i dont really know how to buy a used engine without actually hearing it run
are there some tips you could give me?
i need a complete LS bottom end
and preferably a b16a2 head
is there anyway for me to inspect it to have a good chance of buying an engine that won't give me too many problems?
Old Aug 9, 2011 | 09:52 AM
Hiboost 2.0's Avatar
Default Re: tips on buying a used engine?
Leak down test first thing
Old Aug 9, 2011 | 09:56 AM
kaiba's Avatar
In your case. The best tool is to bring a mechanic that knows Honda.
Old Aug 9, 2011 | 10:12 AM
Builda'Teg_92's Avatar
at least a compression test if you dont have a compressor.
Old Aug 9, 2011 | 10:14 AM
G3teg96's Avatar
i do have a compressor, and i think i'll do a leakdown test
but just curious, how do you do a comp test with an engine out of the car?
do you just hook a battery up to the starter?
Old Aug 9, 2011 | 10:24 AM
yes sir. ok then yea, a leak down would be a better choice then, honda specs are around 10% leakage.
also check motor mount threads that go into the block and make sure there not stripped
try to take valve cover off and get a peek inside, see if it was taken care of with no sludge
also make sure its dry as a bone on the front left corner of the engine where the headgasket is, VERY common place to leak
and then the overall look and story behind the motor.
Old Aug 9, 2011 | 12:24 PM
G3teg96's Avatar
cool, thanks for the tips, i'll be sure to use them when i check out some motors
Old Aug 10, 2011 | 07:09 PM
dreamer143's Avatar
Buying a used engine mostly people have to trust on word of mouth of seller, some sellers clean and clear all outer spots that shows engine life past and remaining. some used car parts seller have system to show (used engines they sell) in start position with detachable battery self and radiator, If so concentrate on engine noise
dumaduma
Sep 7, 2005 06:32 AM
FuNkDrSpOt
Aug 9, 2005 11:52 AM
cheehee
May 2, 2005 04:44 PM
AcuraEL
Nov 24, 2003 05:33 PM
oryanh
Aug 6, 2003 09:41 AM
