Just got Type R valvetrain
Old Oct 2, 2002 | 11:45 PM
CivicEx95's Avatar
Default Just got Type R valvetrain
Finally got my valvetrain from this Ebay auction. 97 JDM Type R
I'm going to put the springs and retainers in my GSR when I get the cams, but I got a couple questions.
1) Are both the exhaust and intake springs the same? Hard to tell but I think they might be different, how can I tell?
2) Inner springs go on intake side correct?
3) Is there an up and down on these springs and how do you tell?
4) The smaller valves are the exhaust?
5) What should I use to clean everything before install?
Thanks, and I'll post pics of the install and how the results afterwards.
Old Oct 2, 2002 | 11:59 PM
GokuSSJ4's Avatar
Default Re: Just got Type R valvetrain (CivicEx95)
intake springs (there yellow ) both inners and outters
Exhaust springs (there blue) both inners and outters
jdmspoonitr's Avatar
if you can't tell what goes where, I would advise you not to do the install urself
Old Oct 3, 2002 | 12:01 AM
00 FBP ItR's Avatar
1. If you look at the spring you can see thats its marking with either blue or yellow paint... that tells you which is intake and which is exhuast.. intake is yellow..
2. Correct
3. Not sure.. i think painted side is up
4. Correct
5. Soak them in some engine degreaser??
Good luck
[Modified by 00 FBP ItR, 1:02 AM 10/3/2002]
Old Oct 3, 2002 | 12:17 AM
CivicEx95's Avatar
Default Re: Just got Type R valvetrain (Spoon1)
Ok, looking at the springs again, it looks like there is some faint blue paint on some, but there is also sort of a lavender color on others. I don't see any yellow clearly painted on them. BUT when I divided them up based on that, it came out to 8 each. AND it looks like the lavender ones are a LIIIITLE bit taller than the others and seem a bit heavier/thicker. Which ones are which?
Old Oct 3, 2002 | 12:24 AM
SurferX's Avatar
Are you sure that's not a GS-R valvetrain? The Type R has two sets of dual springs, where's the other set of inners? The GS-R has one set of dual springs for the intake side.
EDIT: GS-R intake springs = Type R exhaust springs. That would explain why you have blue and no yellow. I'm guessing you have a GS-R valvetrain there.
[Modified by SurferX, 1:36 AM 10/3/2002]
Old Oct 3, 2002 | 12:39 AM
00 FBP ItR's Avatar
Default Re: Just got Type R valvetrain (SurferX)
thats right... i forgot about that...
Old Oct 3, 2002 | 03:18 AM
IN VTEC's Avatar
You'll have to buy another set of inners for the exhaust side.
Painted side faces up. Side with the tighter coiling faces down.
Brake parts cleaner. Walmart.
You'll also have to get the valve seats recut, as well as having the backcut on the valves redone to match.
Old Oct 3, 2002 | 06:09 AM
CivicEx95's Avatar
Wait, you're telling me this is a GSR valvetrain??? WTF? Oh damn, I just noticed in the auction there were 16 inner springs shown, but I only got 8! ARGH! Did I get ripped off??
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1854344954
Old Oct 3, 2002 | 06:27 AM
pissedoffsol's Avatar
25 Year Member
looks like it.... maybe he just forgot to include them-- shoot him an email. Not that it matters now, but i think you paid a lot for a used itr valve train.... ifs its even an ITR valve trian
Old Oct 3, 2002 | 06:45 AM
Hooch'n's Avatar
Default Re: Just got Type R valvetrain (delvtecsol)
Old Oct 3, 2002 | 07:22 AM
SurferX's Avatar
Wow that's really bad. Yeah I'm pretty sure you got a GS-R valvetrain. You still need a set of both Type R inner and outer intake springs. That's a definite candidate for fraud, especially with the pic and all.
Old Oct 3, 2002 | 08:42 AM
IN VTEC's Avatar
I don't think it's GS-R stuff. GS-R valvesprings don't come painted at all.
Old Oct 3, 2002 | 08:46 AM
Willard's Avatar
Default Re: Just got Type R valvetrain (IN VTEC)
are you sure?
Old Oct 3, 2002 | 09:06 AM
dplatt's Avatar
Default Re: Just got Type R valvetrain (Willard)
ITR exhaust springs are the same as GSR intake springs. If you buy ITR springs exhaust springs new, they come in "P72" marked packages and are painted blue. The P73 springs are only on the intake side, and painted yellow. Paint side up during installation. Best of luck.
Old Oct 3, 2002 | 09:14 AM
IN VTEC's Avatar
The ones I pulled from my GS-R motor weren't painted.
But, the part number correspondences make sense.
Old Oct 3, 2002 | 10:56 AM
sgT's Avatar
sgT
All valve springs are painted. Thats how they identify them.
Yellow
Green
Blue
Orange
Whether or not the paint has stayed on over the years is another story.
Dxs
Jun 15, 2008 07:14 PM
bxsi
Dec 27, 2004 07:44 AM
McFly
Feb 12, 2003 08:27 PM
EGkTiOn_CiViC
Dec 1, 2002 09:44 AM
HX_Guy
Dec 20, 2001 01:44 PM
