need help diagnosing problem...
Old Oct 3, 2002 | 10:09 AM
[HrZn]4life's Avatar
Default need help diagnosing problem...
Hey guys...I just wanted to get your opinions on this situation that I'm having with my car. Anyways, it's been going on for awhile now but it happened again last night. I was at the dragstrip last night and after each pass my mph goes down more and more; I'm getting better E.T's after each run (faster and faster after each run) and my launches and mid range times are all getting better...the problem is that after each run despite all the other improvements, my top end and final trap speed is decreasing. And it's decreasing by a lot....by the end of the night my trap speed will decrease by 3 mph, though my E.T's are getting better from better launches and midrange power. I dunno what it is...only thing I can think of is that I'm using some crappy oil and it's just not holding up through the night...what do you guys think? Thanks a bunch.
Old Oct 3, 2002 | 10:11 AM
BlueR's Avatar
Default Re: need help diagnosing problem... ([HrZn]4life)
dude...read your post...you just answered your own question
Old Oct 3, 2002 | 10:15 AM
Dave-ROR's Avatar
wasn't the point of drag racing to have a lower ET? Slicks give you better ET's and lower trap speeds too. High trap speeds can indicate too much wheelspin.. who really cares what your trap speed is?!?
Old Oct 3, 2002 | 10:16 AM
Default Re: need help diagnosing problem... (BlueR)
alright, cool...just wanted to see if you guys agree.
Old Oct 3, 2002 | 10:17 AM
Default Re: need help diagnosing problem... (Dave-ROR)
yeah, but I shouldn't be losing mph as the night goes on unless something isn't holding up in the car.
Old Oct 3, 2002 | 10:20 AM
Dave-ROR's Avatar
This is not true at all. A better launch with less wheelspin and more traction will produce a LOWER trap and faster ET.
Old Oct 3, 2002 | 10:24 AM
BlueR's Avatar
which is exact what he said happened in his original post...
Old Oct 3, 2002 | 10:28 AM
Dave-ROR's Avatar
I know. I was replying to:
Old Oct 3, 2002 | 10:31 AM
Thanks for the opinions guys....it's appreciated. But for the finals word...is it normal or is something probably going bad though the night (ie. my oil not holding up)....???
Old Oct 3, 2002 | 10:32 AM
BlueR's Avatar
hes confusing the hell out of me...i read his original posted and i didn't think there was a problem at all...better launches=lower et times and trap speeds
Reid's Avatar
Global Moderator
It's normal.
Old Oct 3, 2002 | 10:44 AM
Default Re: need help diagnosing problem... (Reid)
Okay....got it. Thanks guys. Sorry for the confusion.
Old Oct 3, 2002 | 10:47 AM
JPP's Avatar
JPP
I am a little confuse as well but for different reason. Isn't the "trap speed" the instantanious reading of the speed at the end of the 1/4 mile run?
Why would a better launch and lower ET equate to a lower final speed ?
For a given car with given gear set-up, if the 1/4 time is lower then the speed should be higher. Or am I mixed up in the terminologie ( I am not a 1/4 mile racer)
Old Oct 3, 2002 | 10:57 AM
Default Re: need help diagnosing problem... (JPP)
Okay...this is what is happening:
first run: ~15.2 @ 91 mph 60ft. ~ 2.3
second run: ~ 15.134 @ 90 mph 60ft. ~ 2.281
third run: ~ 15.101 @ 89 mph 60ft. ~ 2.276
4th fun: ~ 15.030 @ 88.783 mph 60ft. ~ 2.252
---E.T's are getting better with each run; launches are getting better with each run; midrange is pulling harder through each run; MPH is slowing down though.
From what i've learned this is normal. Right guys? Is this normal or not????
[Modified by [HrZn]4life, 8:12 PM 10/3/2002]
Old Oct 3, 2002 | 11:08 AM
vtec.dc2's Avatar
how about 60ft time?
edit that post and ad the 60ft time...
Old Oct 3, 2002 | 11:13 AM
Default Re: need help diagnosing problem... (vtec.dc2)
o btw, this is an integra LS on street tires...if that helps any
Old Oct 3, 2002 | 11:19 AM
vtec.dc2's Avatar
thats what i was wondering.. it seems like low trap speed for type r.. 2.2x is good for for ~15.0 run.. what are your trapspeeds like from other days?
so far it seems about right..
Old Oct 3, 2002 | 11:23 AM
It usually around the same...but the same thing happens. I will start out with my fastest trap and then gradually it will get slower but with better launches and better E.T's.
B20vEf9
31
Jan 6, 2011 06:51 AM
Drew Peacock
Mar 12, 2007 02:48 PM
Panoply
Oct 28, 2006 04:37 PM
AllMotor12s
Jul 17, 2006 12:46 PM
BLK99VTECR
Oct 28, 2003 09:53 PM
