Crankshaft/Oversized thrust washer?
Old Aug 1, 2011 | 01:12 AM
wtf_is_jdm's Avatar
Icon2 Crankshaft/Oversized thrust washer?
ok, I have a B20B sitting at the machine shop awaiting final assembly for my DC. I brought them the LS crank, rods and new B20Z pistons for the B20B4 Block.
Upon bringing them the crank, one of the lead techs said he was concerned about where the thrust washers would sit. There is a small ridge (less than 1/32 in guesstimation) towards the outside away from the center of the crank where the thrust washers are to go.
The crank IMO looks fantastic in every way. No "hotspots" or scarring anywhere on the journals. My question is, will that small ridge be of any problems to the rotating assembly or is it a part of how the crank is made and was meant to be there? He had mentioned about milling it down flush, but is proceeding with caution about that simply because of the uncertainty of availability of "over-sized" thrust washers.
And part two in doing this will it make the engine more or less unreliable due to the possibility of "crankwalk" like a DSM?
Please help me figure this out, I am on motor number 4. My DC has sat more than it has run.
Thanks Guys!
Nate
Old Aug 1, 2011 | 09:07 PM
wtf_is_jdm's Avatar
Default Re: Crankshaft/Oversized thrust washer?
bump
Old Aug 1, 2011 | 09:46 PM
h2.4's Avatar
you're gonna have to post pics. it's like posting a thread saying, "my friend at the bar is saying to bang this chick, He says she's super hot. What should I do?" How do we know what she looks like?
Old Aug 1, 2011 | 09:58 PM
civickiller's Avatar
i thought i remember seeing something about different size thrust washers before, sorry i forget where
Old Aug 2, 2011 | 08:41 AM
wtf_is_jdm's Avatar
Old Aug 2, 2011 | 09:02 AM
that looks like its meant to be like that minus the rust and the polishing needs of the journals
Old Mar 14, 2018 | 03:03 AM
antoni's Avatar
they are on ebay
https://www.ebay.co.uk/itm/Honda-Rov....c100508.m3226
Honda Rover 2.4 2.3 2.2 2.0 1.8 1.7 1.6 16V GTI Vtec (+0.25mm) Thrust Washers
good luck brothers
Old Mar 14, 2018 | 09:41 AM
TheShodan's Avatar
Moderator
8 year post. Please check the dates. But we appreciate the input, Antoni.
Tyler Godley
Engine Machining & Assembly
10
Feb 24, 2019 07:49 AM
Z0831xiz
Apr 26, 2015 03:56 PM
mike1114
Apr 1, 2008 06:47 PM
blkteggy
Jan 18, 2008 01:43 PM
TheSwift1
May 29, 2002 10:42 AM
