del sol knuckle help
Old Jul 24, 2011 | 05:06 PM
Jdcamaros's Avatar
Default del sol knuckle help
i have a 94 del sol vtec i got it and the drivers side tire was cambered in like it was lowered it all stock hight so i got camber kit and it helped alot but still off. i think it a bend knuckle. i got a knuckle off a 95 teggy will this be the same??? or wat car would have the same knuckle cause finding a del sol vtec with the b16 in a junk yard is slim to none....
Old Jul 26, 2011 | 07:19 PM
Jdcamaros's Avatar
Default Re: del sol knuckle help
Anyone?????
Old Jul 27, 2011 | 04:15 PM
Red_Army's Avatar
any del sol knuckle would work. and yes the teg one will work.
after you get it realigned properly throw out the camber kit.
Old Jul 27, 2011 | 04:23 PM
NotAJDMFanBoy's Avatar
I can't imagine a knuckle bending. Check the upper control arms, bushings, etc if anything is bent.
And no, not all knuckles are the same. There's the "DX" knuckle with an 8.8" rotor, the "EX" knuckle with 10.3" rotor (same as an Integra RS) and the ABS knuckle (EX with ABS and Integra LS, GSR" with the 10.3" rotor, but it has bolt holes for ABS line and sensor probably. If you don't have ABS, easy, just use any Integra knuckle and swap your caliper bracket over to use your pads.
I'm not 100% sure if it's the Integra knuckle in general, or the Integra ABS knuckle, but I know one has a different caliper bracket that uses bigger pads
And all Civic, Del Sol and Integra parts can be swapped around, like knuckles can be done in pairs, etc.
Old Jul 27, 2011 | 04:29 PM
98civdx's Avatar
Master Detailer
Knuckles bend. It's not noithing new. BUT, you would have to be a pretty good wreck to bend it.
Also, if you bent the knuckle I am almost positive you would have other bent parts.
Has the car ever been wrecked?
Old Jul 30, 2011 | 02:09 PM
Jdcamaros's Avatar
i ended up replaceing just the drivers side with a knuckle from a 95 integra with abs. took the abs off and did some measurements and everything looks to be the same. going to get coil overs i think skunk 2 kit. the coil overs and shocks. and rear camber kit. than take it to get alighned... and guy below yes i found out that the bushings on the upper control arm were bad i ordered new bushings as well...
mugenNR10
Jul 14, 2011 12:10 PM
blaze2010
Mar 11, 2010 02:00 PM
gmacarize
12
Oct 27, 2008 06:26 PM
aemfreak
Dec 1, 2004 10:53 AM
5thGenFanatic
10
Sep 13, 2004 07:58 AM
