del sol brake question
k i have a 95 sol vtec:
front brake size?
and is there a difference between abs and non abs calipers?
i ask cuz i got a 11in fastbrakes kit lyin around and was wonderin if i could put it to use...
also are teg rear disks the same size as my sols cuz again i got parts lyin around and want them to go to work
thanks
front brake size?
thanks
Re: del sol brake question
https://honda-tech.com/forums/tech-misc-15/reference-brake-rotor-sizes-928196/
I dont think you could use Integra rotors unless you do a complete brake swap.
i was under the impression that del sol vtec w/ abs has 262mm rotors and non-abs is 240mm rotors. in 94 abs was optional then became standard equipment in 95.
now this may sound dumb but what wou stop me from using the 11in rotor just not the caliper? would it be width or the dia of rotor? and could i just use the caliper mount from the fastbrakes kit? or would the caliper not grip the new rotor diameter properly
gmacarize
12
10-27-2008 06:26 PM
delsolnewkid
03-13-2006 07:20 AM
