Low Idle With the A/C On
Old Oct 2, 2002 | 08:41 AM
dubnine's Avatar
Default Low Idle With the A/C On
Can this be caused by my lightened flywheel?
Old Oct 2, 2002 | 09:02 AM
baonest1's Avatar
Default Re: Low Idle With the A/C On (dubnine)
hmm.. i beleive my car idles high with AC on.
Old Oct 2, 2002 | 11:06 AM
Perfectionist's Avatar
The idle compensation circuit should look for and try to obtain the pre-determined idle speed for A/C. I don't think the flywheel should matter.
Old Oct 2, 2002 | 01:07 PM
577HondaPrelude's Avatar
Default Re: Low Idle With the A/C On (Perfectionist)
When your AC kicks on your engine has to power the increased load, thus your idle control unit should let more air bypass your throttle plate which will make your car idle about 200 RPM’s higher. Sounds like your car is not compensating for the extra power needed to run your AC at idle. Could be a problem with your Idle control unit, there should be a step by step procedure for testing your idle control unit in your HELMS manual. Look it up and follow it.
[Modified by 57STS, 5:08 PM 10/2/2002]
Old Oct 2, 2002 | 01:29 PM
dubnine's Avatar
Default Re: Low Idle With the A/C On (57STS)
I think my computer isn't wired up right, its a 2000 type r ecu in a 99 si.
Ohmega
Jul 21, 2018 12:00 AM
Bhi Rds
May 8, 2016 06:19 PM
georgiajdm
Aug 11, 2009 06:31 PM
Grandmasta
Apr 16, 2004 03:28 PM
