idle issues when ac is on...
Old May 2, 2016 | 12:38 AM
Bhi Rds's Avatar
Default idle issues when ac is on...
When ac is off idle is normal but when ac is on idle starts to go down which is reverse and starts to fluctuate
if my idle is 800 at normal when i turn the ac on it goes down to 500-400 and eventually
fluctuate..
if u can share guys regarding wiring tips..it would be a big help
iacv replaced
Old May 2, 2016 | 07:45 AM
fcm's Avatar
fcm
Old Fart
Default Re: idle issues when ac is on...
MM&Y of car would help.
Reset the ECU, it should idle up the engine when A/C is on, that apparently is not happening.
If you manually keep the RPM up, how does the A/C work, cold enough? 94
Old May 2, 2016 | 09:00 AM
v4lu3s's Avatar
RTFM
make sure that base idle is correctly set as well.
Old May 4, 2016 | 10:06 AM
rillest's Avatar
possibly bump up your timing
Old May 8, 2016 | 06:19 PM
kwade9015's Avatar
Idle air control. Clean it you must. Idle better it shall. Maybe. It worked for me.
susy76
May 26, 2013 02:38 PM
Ercol215
May 6, 2013 10:59 PM
Andrew14
Jun 22, 2010 09:24 PM
