VAFC...Does it Have a Mind of its Own?
Here's the deal...
a.) RPM Correction
1000------->0
2000------->0
3500------>-8
b.) Lo/Hi Throttle is at 10%/50%
I'm monitoring the Air Correction Rate on my VAFC and it's registering numbers at instances where I don't think it should. I know the VAFC has a formula for calculating the fuel correction when throttle is between your Lo/Hi throttle settings but...
??? Should it be correcting fuel if my RPMs are below 3500 ???
[Modified by CPR, 12:20 PM 10/2/2002]
a.) RPM Correction
1000------->0
2000------->0
3500------>-8
You set your own correction settings at whatever RPM's. The unit won't just figure it out for you. If your worried about what it's doing just initialize everything back to zero which will be stock settings and then retune on a dyno to your own likings
Sorry, Misunderstood your previous post. That does seem strange. My V-AFC needs to be reprogrammed. The dumb ***** at the dyno I went to set me at +6 for wide and narrow throttle settings from VTEC up. I'm not happy with these settings, but at the time I didn't know enought about fuel correction to make my own settings. Good luck with your problem, let me know what you find out
IgniteTeg
Apr 25, 2002 11:25 PM
