Si front and rear sway bar setup for ek civic
Old Jul 10, 2011 | 08:00 AM
jplowman2005's Avatar
Default Si front and rear sway bar setup for ek civic
sold
Old Jul 10, 2011 | 09:23 PM
import-tooner's Avatar
Default Re: Si front and rear sway bar setup for ek civic
Are the Si forks required for some reason to use a sway bar?? Or is it that you need them to run the LCA's?
Old Jul 11, 2011 | 06:38 AM
talkJDM's Avatar
If you want to run the 26mm Si/CTR Front Sway Bar on the EK you need to change over to the Si/CTR Front LCAs as well as the Forks.
The Front Sway Bar from the Si/CTR mounts at a different location than other 96-00 Civics, thus why it requires these additional two items. The Front LCAs are also thicker where the fork mounts, so other forks will not work and that's why you need those too. That said, you also need a longer bolt to join the Fork and Front LCAs.
Old Jul 11, 2011 | 12:39 PM
what he said, there needed to to run the lcas, which are needed to use the swaybar
Old Jul 13, 2011 | 09:53 AM
$200 firm plus shipping
Old Jul 22, 2011 | 05:38 PM
will not seperate unless someone buys the front first
Old Jul 22, 2011 | 08:56 PM
cdeluise's Avatar
bump, I love my EM1/CTR front sway. Well worth it.
Old Jul 28, 2011 | 12:41 PM
thanks bump
Old Jul 28, 2011 | 01:03 PM
aeros's Avatar
how much u want to sell the front set up for?
Old Aug 1, 2011 | 04:53 PM
shoot me a offer
Old Aug 1, 2011 | 06:35 PM
monEmakindave's Avatar
Wanna sell the forks only? Pm me a price
Old Aug 2, 2011 | 03:30 AM
no its staying together
Old Aug 5, 2011 | 08:39 AM
bump
spoonhbk11
Suspension & Brakes
Oct 10, 2011 06:04 PM
civc 91
Sep 1, 2010 07:21 PM
drew1987
Jan 8, 2008 08:41 AM
SPOONfdEK
21
Aug 8, 2003 03:08 AM
GokuSSJ4
10
Mar 17, 2002 11:11 PM
