94 civic ex wont go past 5400 rpm
Old Jun 30, 2011 | 01:58 PM
bignelson001's Avatar
Default 94 civic ex wont go past 5400 rpm
I recently bought a 94 civic ex with a single cam vtec zc swap with 188000 miles on swap......i tried to gun it but rpm wont go past 5400 which is weird cuz my z6 hits 7400 wid no problems nd i read that dey are similar engines so if anyone can help mi out wid dis thanks
Old Jul 1, 2011 | 04:34 AM
Default Re: help with 94 civic ex
Old Jul 6, 2011 | 02:17 AM
Ttt
Old Jul 6, 2011 | 09:09 AM
DO/\/\O's Avatar
maybe it could be the ecu or something not letting it go pass 5400 rpm....
i have a d15b7 and goes up to 5800 rpm
Old Jul 6, 2011 | 09:53 AM
Former User's Avatar
Default Re: 94 civic ex wont go past 5400 rpm
Please create informative thread titles that reflect your tech question. Title edited.
Old Jul 6, 2011 | 11:38 AM
hatchbackcx's Avatar
It can be your ecu like the guy said. and also check if you have a knock sensor. if you dont have one that might be the problem.
Old Jul 6, 2011 | 06:20 PM
pwebb0207's Avatar
what speed do you top out in each gear? tach could just be inaccurate.
someone please correct me if I'm wrong, but if I recall correctly an EX trans should be around:
1st 35
2nd 62
3rd 92
Old Jul 6, 2011 | 06:46 PM
HondaPartsHero's Avatar
Technical Hero
If you're using a P28 it doesn't use a knock sensor. I'm guessing you have a check engine light lit in the dash?
Old Jul 7, 2011 | 04:16 AM
Im using a p28 nd i have no check engine light
A friend told mi it could be my clutch is that possible?
Old Jul 7, 2011 | 09:58 AM
Gustav129's Avatar
A bad clutch wouldn't keep an engine from reving up. If your clutch was bad, you'll go up in RPMs and not go anywhere. For example, your cruising at 35mph in third gear, you give it some gas, and as the RPMs go up a few hundred you notice you're still going 35mph.
Old Jul 7, 2011 | 10:16 AM
anthony_kim's Avatar
ttt
Old Jul 7, 2011 | 10:18 AM
DO/\/\O's Avatar
it cant be the clutch... check the ecu like i told you... or repleace it with a friends p28
DO/\/\O's Avatar
keep us updated!
Old Jul 8, 2011 | 02:55 AM
If it was the ecu wouldnt dere b a check engine light?
Old Jul 8, 2011 | 09:37 AM
Gustav129's Avatar
No, not necessarily. A bad ECU can recieive good input signals, but still put out bad output signals.
Old Jul 12, 2011 | 03:35 AM
So how do i kno if im buyin a gud ecu ?
Old Jul 13, 2011 | 03:55 AM
Tryed a different ecu nd dis one hit 6k so ima try anotha ecu
Angry_Raisin
Sep 5, 2012 04:36 PM
Chriistiinaaa
Apr 13, 2010 09:23 AM
Disco Dan
Jan 8, 2009 08:15 AM
thisboyjulio
15
Jan 25, 2006 07:19 AM
LittleG112
Aug 17, 2003 10:24 AM
