puke oil thru filter fom breather tank
Old Jun 28, 2011 | 09:16 AM
egcoupe007's Avatar
Default puke oil thru filter fom breather tank
allstar performance breather tank(all36109 u google on images) 2 bungs with filter on top and a drain valve at the bottom i have a ls vtec turbo 426whp at 18psi removed the black box and plugged it i haves 2 hoses from the block to the can same day i drive hard or nex day i shoots out the filter and i have to drain it
egcoupe007 is online now Report Post Edit/Delete Message
Old Jun 28, 2011 | 09:20 AM
egcoupe007's Avatar
Default Re: puke oil thru filter fom breather tank
any suggestion would help thax
Old Jun 28, 2011 | 09:22 AM
egcoupe007's Avatar
any help will do
Old Jun 28, 2011 | 10:01 AM
mr2slo4u's Avatar
You need to have a return line with fitting into the block so it drains back into the motor, or it will just fill up and you will have to drain it manually
jesimmers
17
Mar 15, 2007 10:20 AM
dazcivic
Feb 16, 2007 03:46 PM
asubennett
Apr 13, 2006 04:06 PM
defect08
Mar 13, 2006 06:57 PM
