CRX B16A CODE 21
Old Jun 26, 2011 | 09:44 PM
THE 2BSEEN's Avatar
10 Year Member
Default CRX B16A CODE 21
Hey all. This would of been asked a heap of time im sure but couldnt find any thing useful. So error code 21 just keeps coming up, i followed the troubleshooting flowsheet. but still with no luck, the ownly test i cant do is try another ecu. what esle can i try. the engine is a b16a1. any help would be wicked. broke a finger so want to do it with my time of lol
thanks for any help
Old Jun 26, 2011 | 09:50 PM
gnxpro24's Avatar
Default Re: CRX B16A CODE 21
if youre ecu is obd0 and is flashing a light 21 times without stopping in between flashes it is the vtec solenoid or wiring according to this chart
Diagnostic Trouble Code (DTC) System Indicated
0 Engine Control Module (ECM)
1 Heated Oxygen Sensor (HO2S)
3 Manifold Absolute Pressure (MAP Sensor)
4 Crankshaft Position (CKP Sensor)
6 Engine Coolant Temperature (ECT Sensor)
7 Throttle Position (TP Sensor)
8 Top Dead Center Position (TDC Sensor)
9 No. 1 Cylinder Position (CYP Sensor)
10 Intake Air Temperature (IAT Sensor)
13 Barometric Pressure (BARO Sensor)
14 Idle Air Control (IAC Valve)
15 Ignition Output Signal
16 Fuel Injector
17 Vehicle Speed Sensor (VSS)
20 Electrical Load Detector (ELD)
21 Variable Valve Timing & Valve Lift Electronic Control Solenoid Valve (VTEC Solenoid Valve)
22 Variable Valve Timing & Valve Lift Electronic Control Pressure Switch (VTEC Pressure Switch)
23 Knock Sensor (KS)
30 A/T FI Signal A
31 A/T FI Signal B
41 Heated Oxygen Sensor (HO2S) Heater
43 Fuel Supply System
Old Jun 26, 2011 | 10:14 PM
THE 2BSEEN's Avatar
10 Year Member
16 Fuel Injector
30 A/T FI Signal A
31 A/T FI Signal B
Ive read my code ownly from the ecu. that read long long short.
what is the best way to find out which ecu i have.
Old Jun 26, 2011 | 10:17 PM
gnxpro24's Avatar
your ecu will say on the side what is. examples- pr4 p28p75 pm5 PW0 im guessing you have an obd0 PW0 or PR3 or even an obd1 p28. heres how to see if its obd0 obd1 or obd2 most likely obd0 or 1
http://www.hondata.com/techecuid.html
Old Jun 26, 2011 | 10:33 PM
THE 2BSEEN's Avatar
10 Year Member
yep pr3
Old Jun 26, 2011 | 10:48 PM
THE 2BSEEN's Avatar
10 Year Member
what your thoughts on fixing my error code
Old Jun 26, 2011 | 10:53 PM
gnxpro24's Avatar
anytime an ecu has an led light that blinks codes its obd0
check your vtec solenoid wiring. my guess is whoever did the wiring didnt wire it correctly so now the ecu recognizes that and throws the cod
Old Jun 27, 2011 | 01:41 AM
THE 2BSEEN's Avatar
10 Year Member
Yeah ill go though it tomorrow. ill try to clean the vtec solenoid unbolt n see whats it like. i did run a wire from the ecu plug to the vtec solenoid, then use a voltmeter to see if i got any thing which i did so wire should be ok.
Old Jun 27, 2011 | 06:30 PM
THE 2BSEEN's Avatar
10 Year Member
wires look good. i clean the vtec solenoid. i ran a wire from battery to the vtec solenoid, it makes a pop sound so i guess it works. still have the code any ideas
Old Jun 27, 2011 | 09:10 PM
THE 2BSEEN's Avatar
10 Year Member
I looked and looked and think i found my problem. on the very end of the ecu plug i found the wire broken off. the trouble is there is like 2mm left of wire, i have soilder it but dont think its good enough. can i wire to a different wire on the ecu
thanks for some help
Old Jun 27, 2011 | 09:35 PM
gnxpro24's Avatar
I think I know what you mean. upload a pic of the broken wire once and Ill tell ya
Old Jun 27, 2011 | 09:42 PM
THE 2BSEEN's Avatar
10 Year Member
next thing how do i put pictures up. send me your email address. i have hooked a wire up but still didnt work.
so hard to take pics of it.
ill try to explain it better, the wire to the VTEC Solenoid Valve has broken off at the plug to the ecu, i did soilder it but hasnt worked, can i splice it to another wire on the ecu plug
Old Jun 27, 2011 | 09:57 PM
gnxpro24's Avatar
join photobucket and upload your pics to their site and then copy the link and put it in a post and it appears as a picture
Old Jun 27, 2011 | 10:25 PM
THE 2BSEEN's Avatar
10 Year Member
THANKS.i did email some to you but yeah wire broken where it first comes off the ecu plug.
I read this on a prelude site
ah hah! it was electrical! wire was dead somehow...no current runnin!
so i had the ecu pin hotwired to the 1 pin connector...code is gone and car is no longer in limp mode again! how odd...must have gotten cut or something...
Old Jun 27, 2011 | 10:28 PM
gnxpro24's Avatar
figured. looks like you have enough wire to work with if ur careful and when you solder it unplug it form the ecu to avoid damage to the ecu form the heat. make sure you solder and heat shrink then. if you dont have enough wire left depin that wire from the ecu plug an pin a new one in
Old Jun 27, 2011 | 10:31 PM
THE 2BSEEN's Avatar
10 Year Member
yeah the wire broke lol. how do i pin a new one
Old Jun 27, 2011 | 10:36 PM
gnxpro24's Avatar
do you have ne ecu plugs from an old car harness you can use?
Old Jun 28, 2011 | 01:00 AM
THE 2BSEEN's Avatar
10 Year Member
DONE,put a new wire to replace the old on but no sure if itll work. will try tomorrow. finger x. im guessing vtec hasnt been working. so could be a good thing to fix.
thanks
Old Jun 28, 2011 | 02:04 AM
gnxpro24's Avatar
hopefully vtec works now
Old Jun 28, 2011 | 05:16 PM
THE 2BSEEN's Avatar
10 Year Member
VTEC YO, Thanks for your help champ all fixed
EMTIV09
Engine Management and Tuning
May 16, 2011 06:03 AM
CustomX113
11
Sep 1, 2006 01:27 PM
Phrost
May 29, 2006 02:44 PM
xxthabest1xx
Mar 15, 2003 06:06 PM
XzzYzzX
Dec 10, 2002 03:18 PM
