cant go past 4500 rpm
Old Jun 26, 2011 | 05:28 PM
niceguy07036's Avatar
Default cant go past 4500 rpm
Ok so heres my setup i have a 97 accord f22b1 60 trim turbo, 440 injectors, p28 with a obd2 to obd1 step down harness so i cant read check engine codes, aem fpr and fuel rail…………………… this is my problem before i bought the aem fpr i had an ebay fpr and i was redline and now that i have aem one i cant there both set at the same pressure i dont know whats wrong any advise will helpu
Old Jun 26, 2011 | 05:41 PM
Default Re: cant go past 4500 rpm
Bump to the top i need help
Old Jun 26, 2011 | 06:24 PM
civickiller's Avatar
So u have a cel? so Why can't u check the code?
Old Jun 26, 2011 | 06:33 PM
No cel and ive talked to one of the guys at c&m they said the reason why i cant read codes with a scanner is because obd2 cars have somethings obd1 dont so it cant read it
Old Jun 26, 2011 | 10:29 PM
You need to jump the connector under passenger side dash with a paper clip.
A light blue connector I believe then your cel will flash the codes
so what happen when you hit 4500? Limiter?
Old Jun 26, 2011 | 10:46 PM
Ill check for the blue connctor in the morning it sounds like it hitting 2 step which i dont have
Old Jun 27, 2011 | 09:28 PM
To the top .......
Old Jun 28, 2011 | 06:05 AM
109 view and only 2 comment
Old Jun 28, 2011 | 07:29 AM
ef92b's Avatar
check your VSS. wiring and/or sensor issue probably.
honda305
Jan 7, 2009 08:37 PM
b18c-ivic_gsR
Sep 28, 2004 04:45 PM
beeroh
Sep 24, 2004 08:16 AM
Visionist
Jul 13, 2003 10:53 AM
Mugen Dom
Oct 6, 2002 06:33 PM
