Need advice on checking a motor before purchase
Old Jun 26, 2011 | 10:50 AM
Randysi's Avatar
Default Need advice on checking a motor before purchase
Okay so im going to go buy a d16a6 long block motor for my 1989 honda civic si for $200. What are some ways to make sure it will run before purchase?
Im pretty sure if I can hand crank it and it seems to have compression in all four cylinders it will run right?
I believe my only worries should be the piston rings? correct?
Old Jun 26, 2011 | 12:33 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Need advice on checking a motor before purchase
A compression test tells less than half the story. If you want to check it out the best you can without actually running it, leak-down testing is the ONLY way to accurately gauge the condition of the motor. With the two combined it will show you exactly where that motor stands mechanically.
Old Jun 26, 2011 | 02:35 PM
Randysi's Avatar
Can I perform an acurate leak down test with the motor out of the car?
Old Jun 26, 2011 | 03:13 PM
DO IT ON ALL FOURS
Yes - actually a compression check is about 5x more difficult out of the car. A leak-down test is the only easy test being that you actually DON'T want the motor to turn over when you are performing it; unlike a compression test where you have to turn the motor over.
Old Jun 26, 2011 | 03:42 PM
Randysi's Avatar
Okay thanks. Would a place like auto zone or andvanced auto parts do a compression test on the motor if i brought it to the store in the back of a truck? Im sure I could do it my self but im just wondering.
Old Jun 26, 2011 | 03:44 PM
phirewire's Avatar
I'd have to say no, but if you took it to a garage I'm sure they would.
Old Jun 26, 2011 | 05:05 PM
Randysi's Avatar
Say like the garages at walmart where they do all there automotive stuff? Think they would?
Old Jun 26, 2011 | 05:09 PM
Randysi's Avatar
I meant to say leak down test^^^
Old Jun 26, 2011 | 05:20 PM
DO IT ON ALL FOURS
I can assure you no parts stores or Wal-Mart style supermarket people will do the tests let alone probably even know what they are.
Old Jun 26, 2011 | 05:32 PM
phirewire's Avatar
Your gonna just have to stop at some garage along the road, any garage *garage* will know and do it for you.
Old Jun 27, 2011 | 04:37 AM
1990edsedan's Avatar
check this:
http://www.youtube.com/watch?v=ofSiTGeLXvc
you can rent the gauge from some autoparts store (well at least here in Canada)..
Old Jun 27, 2011 | 06:12 AM
Randysi's Avatar
Okay thanks guys. Im gonna have to look around for a local garage, And actually I have a buddy that has one of these testers(well im pretty sure he does) and Ill ask him about it. Thanks for the help. Ill let you know how the engine is after all this is finished.
DpQInteg
May 2, 2006 01:28 PM
B18EG6
Jan 29, 2006 02:24 AM
B16Drag
Apr 27, 2005 11:11 AM
JDMEMM
Oct 21, 2002 10:56 PM
