compression check D16a6
Old Jun 24, 2011 | 08:27 AM
j3wman's Avatar
Default compression check D16a6
so i did a compression check on my 91 si with a d16a6 and i got 119-122-121-124. they're consistent but consistently low, it burns oil especially bad in cylinder 3 (second away from front of engine).
I'm assuming piston rings but i got no basis other than it burns oil really bad from 600-2000 rpm and when i kick on it. it burns not as bad but visibly when idling and when i tap on the gas after coasting for a while. Does anyone else think of any reasons why it'd burn this bad with that consistantly low of compression?
Old Jun 24, 2011 | 08:43 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: compression check D16a6
Motor is tired - your rings are shot.
"...Now me and the mad scientist are going to have to rip apart the block and replace the pistons rings you just fried..."
Old Jun 24, 2011 | 08:44 AM
ThatRicerDaniel's Avatar
Pull your plugs and put a table spoon full of oil down each cylinder then reinstall plugs and redo compression test. If the compression gets better then it will confirm you have bad rings.
Another test that may help you is to die your oil so you can make sure that the oil you are burning is from a internal source and not a leak on a manifold or something to that effect.
I believe you should be looking for the 160-165 range (but I may be wrong) so 120's would be pretty bad.
have you owned the car a long time? Sounds like some one didnt know how to install rings.
Old Jun 24, 2011 | 08:45 AM
raene's Avatar
If you're coasting down in gear that can cause oil to weep past the valve stem seals into the intake and exhaust and burn off when you get on the throttle, if the stem seals are done.
Old Jun 24, 2011 | 01:43 PM
1990edsedan's Avatar
Time for swap or rebuild.
Old Jun 27, 2011 | 01:47 PM
raffaelli's Avatar
Did you do a leak down? that will tell you where you are losing compression.
skata89
Dec 21, 2007 11:13 AM
turbo-crx
Oct 10, 2007 09:29 AM
iBrandon
Apr 19, 2006 03:51 PM
hondaeg8
10
Jul 25, 2004 11:13 AM
Witty
Jul 3, 2003 06:20 PM
