HELP: O-Ringed block
Old Jun 20, 2011 | 07:26 PM
gizzmo222's Avatar
Default HELP: O-Ringed block
I was just wondering if the block has to be re-o-ringed when the head is pulled off. The head gasket had blown on my car and it needs to be replaced. Any help is appreciated and if anyone could point me into the direction of anyone that could help that would be great.. thanks in advance.
Old Jun 20, 2011 | 07:48 PM
85mmek9's Avatar
Default Re: HELP: O-Ringed block
Yes always replace the copper orings everytime the head its takin off. I learned that the hard way.
Old Jun 20, 2011 | 07:49 PM
SPOOLINmatt's Avatar
yes, they crush, therefore they must be replaced.
Old Jun 20, 2011 | 09:27 PM
gogetta's Avatar
Just call me!
Old Jun 20, 2011 | 11:47 PM
Boosted_B_Series's Avatar
any sources on the wire?
I have a ge o ringd block
Old Jun 21, 2011 | 05:26 AM
Topdawgg's Avatar
I always replace mine..
Had a hard time finding the proper wire locally though.
ended up finding someone around here that had a new spool of the GE stuff, luckily.
I believe its 18 gauge soft copper.
Old Jun 21, 2011 | 06:49 AM
2fastGSR's Avatar
King of the One Liners
Yes replace it. We purchase our wire from InlinePro in Va.
Old Jun 21, 2011 | 06:50 AM
Blown90hatcH's Avatar
Get it from GE or McMaster. Yes replace it.
Old Jun 21, 2011 | 12:49 PM
hondaracing84's Avatar
You can order the copper wire spool they use directly from the golden eagle website. That is where I got mine. And you get plenty.
Old Jun 21, 2011 | 01:03 PM
061000rr's Avatar
http://www.mcmaster.com/#oxygen-free...r-wire/=cujo4o
is this the right wire? 8873K15
Old Jun 21, 2011 | 06:45 PM
gizzmo222's Avatar
Well I drove from PA to Queens to get the wire got all the way back and the old wire won't come out, looks like I am going to have to take the block out...
Old Jun 21, 2011 | 07:25 PM
sharp pick
Old Jun 21, 2011 | 07:33 PM
hondasarethebest's Avatar
use a sharp pick to break the wire and then get under to pop a side up but make sure NOT to grab the wire with your hands as it will cut the hell out of you.. I used sharp pick and needle nose pliers
Old Jun 21, 2011 | 07:41 PM
HR-1320's Avatar
I go to sears or home depot to buy the wire, 18ga solid copper wire, lol
Old Jun 22, 2011 | 03:40 AM
Topdawgg's Avatar
yea, those wires can be a BI*** to start, but they pull right out once you lift it in one spot.
Old Jun 22, 2011 | 04:38 AM
TheWickedOne's Avatar
Ace Hardware/Sears Hardware, In the aisle where they sell all the stuff to hang pictures. Nothing special to copper wire
Old Jun 24, 2011 | 11:37 AM
kbouchard1092's Avatar
I never replaced mine when i changed my headgasket... The place who machined my block said it wasnt nessacry if it wasnt damaged...i have seen other threads that people havent done it either... I wasnt comfortable taking it out...it still had a slight raise to it and wasnt damaged so didnt feel the need to change it... I have had zero issues after over 3000k miles... My issues was the cometic headgasket i was using. Went to oem with copper spray and have not had a issue since.
By all means if you feel comfortable changing it yourself then do it...but it has to be a flawless seam and cannot have any gaps.
I didnt change it and had zero issues. the cometic gasket is junk im never using anything besides OEM for headgasket ever again
I had gotten cometic so that it would match my 81.5mm bore...which in the end turned out to be a bad decision.
got-vtec?
Jul 27, 2011 04:32 PM
H20too
Oct 23, 2005 02:58 PM
ITR9788
Feb 9, 2004 08:28 AM
