Any extra steps for o-ringed block?
Old Oct 22, 2005 | 03:22 AM
H20too's Avatar
Default Any extra steps for o-ringed block?
I'm putting my o-ringed block together and was wondering is there anyting else i should know before i put my head on... I've heard that i should spray some copper gasket on both sides of the head gasket to make the o-rings flush. Anything else? Also will any 18 ga copper wire work?
One of my friends just put the head on his oringed block and didn't spray copper gasket and he had water leaking from between the head and block causing the car to run hotter than it should have been. Any professional help would be appreciated!!
-Russ
Old Oct 22, 2005 | 10:04 AM
Redwidow's Avatar
Default Re: Any extra steps for o-ringed block? (H20too)
18 is fine but make sure its a soft copper, there are a few different types of copper wire some have clear coatings on them, I picked some up from ACE hrdware for $3 and worked for me. I also spray Copper Spray on both sides of HG. You should be gTg.
Old Oct 22, 2005 | 10:30 AM
ScottEK's Avatar
Default Re: Any extra steps for o-ringed block? (Redwidow)
so are you guys just stripping this standard wire and using it in your block?
Old Oct 22, 2005 | 03:27 PM
H20too's Avatar
Default Re: Any extra steps for o-ringed block? (ScottEK)
what do mean "stripping wire"? it comes on a roll, just bare copper...
Old Oct 22, 2005 | 05:15 PM
Jared's Avatar
I use heavy copper spray on all metal headgaskets
Old Oct 22, 2005 | 11:58 PM
Redwidow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScottEK &raquo;</TD></TR><TR><TD CLASS="quote">so are you guys just stripping this standard wire and using it in your block?</TD></TR></TABLE>
No it is bare copper wire... as H20too said
Old Oct 23, 2005 | 05:22 AM
H20too's Avatar
sounds easy enough, i guess arp head studs are no question when it comes to doing this, huh?
Old Oct 23, 2005 | 07:30 AM
gritsak's Avatar
i would anneal the copper wire to make it softer.
Old Oct 23, 2005 | 08:49 AM
H20too's Avatar
Default Re: Any extra steps for o-ringed block? (gritsak)
explain "anneal" please...
Old Oct 23, 2005 | 08:55 AM
Soccerking3000's Avatar
heat it up so the molecules are farther apart in the metal itself so its easier to work with, more ductile et cetera
this is usually done with a torch but i would put it in an oven or something so you dont get any residue on it
Old Oct 23, 2005 | 09:37 AM
H20too's Avatar
Default Re: Any extra steps for o-ringed block? (Soccerking3000)
i beleive i can handle that, are gloves an option?
Old Oct 23, 2005 | 09:56 AM
no you cant use gloves
Old Oct 23, 2005 | 10:10 AM
gritsak's Avatar
just heat the wire evenly..usually right as it starts getting red, then dip it in water.
there will be a film on the copper that you can get off with some type of acid (cant remember what its called) or gently work it with some high grit sand paper...you can just leave it on as well i think. shouldnt matter.
if you search google you might come up with more info on annealing
Old Oct 23, 2005 | 11:53 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gritsak &raquo;</TD></TR><TR><TD CLASS="quote">just heat the wire evenly..usually right as it starts getting red, then dip it in water.
if you search google you might come up with more info on annealing</TD></TR></TABLE>
i wouldnt dip it in water, that'll quench temper the copper and make it harder but more brittle, and not as eay to work with...
Old Oct 23, 2005 | 12:35 PM
gritsak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">
i wouldnt dip it in water, that'll quench temper the copper and make it harder but more brittle, and not as eay to work with...</TD></TR></TABLE>
thats how i did it for my block and it had no ill effects...the wire was still really malleable...but if thats the case probaby better to let it air cool just to be safe.
Old Oct 23, 2005 | 01:08 PM
thats a much better idea, most metals will become more ductile when they are heated to just below their recrystalization temperature and allowed to normalize to room temperature. Here is a test i did last week on heat treatments/affects
Old Oct 23, 2005 | 02:10 PM
Justin Olson's Avatar
Its good to cut a recever groove into the head so the the head gasket displaced by the o-ring has a place to go.
Old Oct 23, 2005 | 02:58 PM
H20too's Avatar
Default Re: Any extra steps for o-ringed block? (Justin Olson)
it's got a groove, you can't really o-ring a block without one...
eg:R
Feb 24, 2015 10:53 AM
got-vtec?
Jul 27, 2011 04:32 PM
gizzmo222
Jun 24, 2011 11:37 AM
grand champ
Sep 29, 2010 08:59 PM
WREKONIZE V8 KLR
Apr 6, 2005 10:40 AM
