Slicks/Gearing/Downfall Questions
Old Jun 20, 2011 | 07:44 AM
TurboSpoolinInside's Avatar
Default Slicks/Gearing/Downfall Questions
So excuse me for my newb-ness to FWD/slicks, but I am needing to know this.
I have a K20a-T that makes 520whp. It has a base RSX tranny w/ pretty long gears.
info on car: 98 Integra GSR, 8600 redline, RSX Base 5spd tranny, 520whp/369tq
I've used http://www.fatboyraceworks.com/gears/ calculator to figure out my gearing and mph through the gears.
4th gear is quite long and I assume my car will trap between 130 and 140 (optimistic) with perfect conditions...
Now, I don't have slicks and am planning on borrowing some for just a few passes. Using that calculator on the above link, I could get away with 22's and still have 4th gear top out at 139mph.
I am told I want 24.5's but with tires that tall, I'd have really long gears (4th would goto 155mph)
with 23's I would get 4th to go 145mph.
Now, the question is, is there anything BAD about getting smaller tires when my tranny's gearing will end up compensating the mph correctly?
I have only raced AWD cars and haven't ever used slicks and messed w/ tires/gearing so I really don't know.
ANY input would be appreciated. A friend is willing to let me borrow his 22" slicks if I want. I just don't know if it's worth trying then or if I should try and find 23" ones instead.
Old Jun 20, 2011 | 07:48 AM
turbo-2nr's Avatar
Default Re: Slicks/Gearing/Downfall Questions
a 22 is not going to be enuf tire for that much power go with a 24.5
Old Jun 20, 2011 | 07:49 AM
Even if the gearing is there?
Old Jun 20, 2011 | 08:05 AM
HPgonewild's Avatar
the 500hp will over power the 22s since its a small tire. Then your gearing will somewhat be thrown out the window since there is going to be wheel spin.
The gearing calculators will only work if there is no wheel spin and in perfect conditions where there is traction. I wouldnt sacrifice proper tire height for gearing "calculations". Its one of those things that you just have to try out for yourself and see how the car reacts to it.
Old Jun 20, 2011 | 08:07 AM
Would you think 23's would even work? I have a friend who'd let me borrow those too. I just don't want it to be too "doggy" if I found a set of 24.5's.
Old Jun 20, 2011 | 08:18 AM
HPgonewild's Avatar
Id try the 23s and see how that goes.
Old Jun 20, 2011 | 08:21 AM
sanman000719's Avatar
24.5 on my stock gsr tranny with 550 h.p. traps 145mph
Old Jun 20, 2011 | 08:39 AM
Gearspeed-Performance's Avatar
I agree and would try the 23's as HP stated first.
Old Jun 20, 2011 | 10:34 AM
Will do, we'll try 23's! Thanks.
Old Jun 20, 2011 | 05:31 PM
dturbocivic's Avatar
how many rpms are you actually making 520~ hp ? post ur dyno graph
Old Jun 20, 2011 | 05:55 PM
SL0WEGG's Avatar
Old Jun 20, 2011 | 06:06 PM
if u rev it out to 10,500 or 11, does the power stay flat or does it drop ?
Old Jun 20, 2011 | 06:21 PM
Gunmetal_B20_Hatch's Avatar
You also have to factor in tire growth once you are doing 100+ mph.
Old Jun 20, 2011 | 06:29 PM
who cares about growth, them tires are ****ing tiny. put the 24.5's on the car and rev the **** out of the car, if the power is there the car will go fast.
Old Jun 20, 2011 | 06:52 PM
SL0WEGG's Avatar
He thought about using my baby slicks lol. But I believe he has found some 24.5's he's able to use
Old Jun 20, 2011 | 06:55 PM
now rev it up like big boys...
Old Jun 20, 2011 | 06:57 PM
Divers's Avatar
Whats the correction factor on that dyno graph? 520hp dyno dynamics uncorrected is alot. You're gonna want the "out of the hole" traction that 24.5" will give you.
Old Jun 20, 2011 | 07:01 PM
Divers's Avatar
K20R only 8600rpm?!?! Rev it higher and that will help you fall into a better spot going into 4th.
Old Jun 20, 2011 | 09:33 PM
Krut's Avatar
98 DC2 - Stock Unopened Longblock K20a2-T<<<<from his sig
Old Jun 21, 2011 | 03:57 AM
It is 11% corrected and it is a completely stock motor/head/never opened so I personally don't know what its "safely" rev-able to, to be honest.
I did find someone who'd lend me 24.5's, but decided against going to that track. I am gonna goto another track and use some 23x8's that will be available to me... hopefully I get half decent runs.
Old Jun 21, 2011 | 04:15 AM
i was still running 24.5 on 400 h.p running mid 11's at 133
Old Jun 21, 2011 | 09:35 AM
What would the downfall of me getting 26x8x15's be... if I found a really good deal on them? I'd have to raise my front up but I mean it'd just be for the track... Too big? Would I bog too hard/potentially break axles easier?
Old Jun 21, 2011 | 09:41 AM
turbo-2nr's Avatar
they will brake axles and trannys
paulzy
Jun 29, 2010 12:36 PM
1sikhatch
Transmission & Drivetrain
May 19, 2009 08:58 PM
See Are X
Feb 19, 2007 07:22 AM
EH2LS
Sep 28, 2003 03:52 PM
DLB1994
May 19, 2003 06:48 PM
