Help car wont start
Old Oct 1, 2002 | 11:45 AM
wanttorace's Avatar
Default Help car wont start
one day i was pulling my dash off than went back to start the car and it will turn over but it wont start im getting no spark its a 89 crx si any help would be appreciated thanks
boostedrex@hotmail.com
Old Oct 1, 2002 | 02:06 PM
Chiovnidca's Avatar
Default Re: Help car wont start (jjd493925)
Did you check your fuses?
Old Oct 1, 2002 | 02:26 PM
wanttorace's Avatar
Default Re: Help car wont start (Chiovnidca)
yeah i checked every fuse im thinking it could be the ecu or the coil pack in the distributor but im not sure
Old Oct 1, 2002 | 02:41 PM
Chiovnidca's Avatar
Disconnect both wires from the coil and connect a test light between them. Have someone crank the engine. If the light flashes the igniter is good and the coil is bad.
Old Oct 1, 2002 | 04:20 PM
BreakStuff's Avatar
New User
and correct me if i'm wrong...
if a power signal exsists at both coil wires with ignition on, this will also determine a bad ignitor...
Old Oct 1, 2002 | 04:27 PM
H22_Dreamer's Avatar
Default Re: Help car wont start (BreakStuff)
Just a thought, Hows the battery?
I mean sometimes they short out and you wouldnt even know it was low
Old Oct 1, 2002 | 04:29 PM
Chiovnidca's Avatar
No. You have to crank the engine to see if the igniter is grounding the negative side of the coil or not.
Old Oct 1, 2002 | 05:45 PM
wanttorace's Avatar
It is the icm in the distriutor ran a check on the voltage to the ignitor and it has no power so if you have a spare email me FOR Cheap come on hook me up
thanks for all the help
Old Oct 1, 2002 | 05:52 PM
Chiovnidca's Avatar
You should have power on the blk/yel wire at the igniter. If not you have other problems.
Old Oct 1, 2002 | 06:46 PM
BreakStuff's Avatar
New User
But I think there is a certain situation when both poles will have a 12v, normally the 12v signal should be on the blk/yellow w/ ignition on... and the White/blue from the ignitor should only have negative signal... but if the ignitor is bad, in most cases, that white/blue or blue/white will also have that 12v signal when it should not... both poles would be hot...
I'll have to confirm this to refresh my memory... i usually use the method of taking the negative signal from the ECU and supplying that signal directly from the battery to trick the ECU(actually tricking the ignition components) into thinking the motor is spinning, thus sending signal to the ICU,Coil, etc,etc....
[Modified by BreakStuff, 10:55 PM 10/1/2002]
Old Oct 1, 2002 | 08:00 PM
fixhondas's Avatar
Both coil wires will be hot with the key on and no cranking. I just check for a pulsing ground at the negative coil wire during cranking with a test light.
Old Oct 3, 2002 | 07:01 AM
wanttorace's Avatar
Default Re: Help car wont start (fixhondas)
does anyone have a distriubtor for 88 and up honda that wthey want to get rid of thansk
Old Oct 3, 2002 | 02:11 PM
fixhondas's Avatar
I have one, the ears are trimmed so that it will fit a Z6 but it will still work fine for your Si. Make an offer.
Old Oct 3, 2002 | 02:56 PM
Mikey's Avatar
Default Re: Help car wont start (Youarestupid2)
Maybe it's the lack of 4 cylinders!!!!!
Maybe it's lack of a ***** that motivates you to come to Honda-Tech and make fun of us.
[Modified by Mikey, 5:57 PM 10/3/2002]
Old Oct 3, 2002 | 02:57 PM
poison's Avatar
Default Re: Help car wont start (Mikey)
lol, don't worry about the dude. he's gone
Old Oct 5, 2002 | 09:09 AM
wanttorace's Avatar
all i need is the icm and that cost 80 from auto zone so im not willing to pay anything more than that
how does 45 sound
Old Oct 5, 2002 | 10:31 AM
fixhondas's Avatar
You could get a Honda one for $80- don't buy that autozone ****- it is garbage. Sure, I'll do $45. Do you do paypal? Email me at FixHondas@insight.rr.com with info.
88JDMmade
Mar 4, 2010 04:13 AM
cs1985
Mar 10, 2008 04:17 PM
my_hidden_romance
May 27, 2007 12:12 PM
94_CRVtec
Jan 6, 2005 11:48 AM
accordfreak
Mar 9, 2002 10:55 PM
