Transmission & Drivetrain Gearboxes, Differentials, Clutches
shift change assembly and interlock problem???
Old Jun 18, 2011 | 04:06 PM
91CRX-T's Avatar
Default shift change assembly and interlock problem???
I got an A1 tranny that had the shift change assembly missing and the interlock was in the tranny. I got a new shift change assembly and installed it (fit perfect) when i went to install the interlock the shaft that goes into the hole of the shift change assembly does not line up correctly (off by about 1/8 inch or so). I can get it installed all the way but when it in completely its sitting at an angle and its very difficult to get it to shift gears. Could i modify the shift change assembly by drilling the hole out so that everything sits even???
Old Jun 19, 2011 | 07:36 AM
David @ Synchrotech's Avatar
Default Re: shift change assembly and interlock problem???
Drilling a new hole will not work. Have you closed the cases and tried shifting the trans? The main case will hold the pin in the correct position. If it will not line up to close the case, something is bent or you have the wrong part. Post some pics if possible.
Old Jun 19, 2011 | 09:46 AM
91CRX-T's Avatar
I haven't closed the case and tried shifting it only with the case open. I'll try closing the case and if that doesn't work I'll post some pics. Thanks
Old Jun 21, 2011 | 12:42 AM
Mista Bone's Avatar
D Tranny Guru
The curse of the B cases.
Years to master......
stevenDAtegra
12
May 3, 2010 10:57 PM
mmmbrapND
Apr 7, 2009 06:18 PM
htwannabi
Nov 1, 2008 07:45 PM
sieger
Apr 4, 2003 10:45 PM
