93 integra key sticks
When I put it in park and I look at the park light on cluster the park light is not lite up and I can not get my key out of ignition and I mess with the shifter a little sometimes takes 15 min for the park light to be lite up then I can get key out.if anyone can help to fix problem it would be nice
Remove console so you can access the A/T gear position switch... #4- SWITCH ASSY., AUTOMATIC TRANSAXLE GEAR POSITION http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal
Remove the switch, carefully open the swith up and clean it out, put some greas into it and close it up, reinstall and adjust so when in park the park indicator turns on and ign key can be removed. 94
