auto to manual conversion question
1994 Integra LS
so i been doing some searching and i came up with this list of parts
please help me make sure i have all the parts needed on this list so i can start buying them and get this conversion started
5 speed pedal assembly
clutch master cylinder
clutch fluid lines
manual starter
shift linkage
top transmission mount
p75 obd1 Ecu
manual transmission
clutch
flywheel
am i missing anything else ???
clutch fluid lines
manual starter
shift linkage
p75 obd1 Ecu
manual transmission
clutch
flywheel
you will also need to get the manual cluster (preference)
doing an auto manual swap is not that hard, just a little time consuming..
FYI: you should fiberglass the hole that your going to have in the center console, or whatever way you want to cover up the hole.. it keeps the exhaust and element from entering your car that way..
ya ur also missing flywheel bolts because the manual bolts are longer then the auto and ur also missing the rear L bracket for the manual transmission, not sure if anyone mentioned all u need is the mid shaft or half shaft the axles on ur car now should work. i did this on my 97 db7 a few months back.
1994 Integra LS
clutch fluid lines
manual starter
shift linkage
p75 obd1 Ecu
manual transmission
clutch
flywheel
clutch fluid lines
manual starter
shift linkage
p75 obd1 Ecu
manual transmission
clutch
flywheel
I actually just finished up my swap. We shaped & cut a piece of sheet metal and tack welded it to close the gaping hole in the shifter tunnel. A bit of seam sealer and paint and it was like OEM.
Things that I forgot, that I needed,
Top Tranny Adapter mount.
Rear Tranny L bracket
OBD2 Speed Sensor
5spd Starter
5 speed half shaft
new tranny axles seals. (just swap em while the axles are out)
I am now looking for a OBD2 LS manual ECU to get rid of my CEL
OBD2 Speed Sensor
5spd Starter
5 speed half shaft
there is actually a sticky thread for this if you go look, i lists all the parts and then has another thread with the how to do
https://honda-tech.com/zerothread?id=1255332
https://honda-tech.com/zerothread?id=273253
edited: these are the two
sk8board{Pete}
Apr 9, 2013 05:16 AM
