Did a compression test #'s a little low?
Old Sep 30, 2002 | 07:23 PM
Andrew 825SM's Avatar
Default Did a compression test #'s a little low?
I did a compression test on my car with a warm engine and cranked it 7 revolutions and ended up getting 180-185 across the board. I was informed that gsr motors are suppose to get 210 compression. I dont know why my compression is so low. Comments?
Old Sep 30, 2002 | 07:34 PM
Ri5e's Avatar
Default Re: Did a compression test #'s a little low? (NHB Fighter)
Those are good compression #s. If it was 150 or less, then I would be worried.
Old Sep 30, 2002 | 07:44 PM
95GS-Racin's Avatar
Default Re: Did a compression test #'s a little low? (4 Stroke)
Yea, i just did one on my car the numbers were all 200, give or take 2 psi. My car has 100,000 on the odometer too.
Old Sep 30, 2002 | 07:49 PM
Default Re: Did a compression test #'s a little low? (95GS-Racin)
My motor only has 16,000 miles on it also. Im not sure, but could it be from the turbo wearing out my engine. Maybe I have bad piston rings? BTW I did a compression test on my friends car which is a prelude with 30k and he was getting 205 across the board. So I know its not the guage.
Old Sep 30, 2002 | 08:28 PM
gsrstyle's Avatar
did u do while the engine was warm? and did u crank it with the gas down?
my first time i did the test i got 115 across, then the next day i warmed up my car and cranked it at WOT i got 250 across.
if you think your piston rings are bad use oil as a temporary seal. put oil in cyclinder. if your compression goes up alot, then your rings r bad, if it doesnt its your valves or headgasket
[Modified by gsrstyle, 5:32 AM 10/1/2002]
Old Sep 30, 2002 | 09:49 PM
Default Re: Did a compression test #'s a little low? (gsrstyle)
yea engine was warm and gas was at WOT
Old Sep 30, 2002 | 11:06 PM
leechungsr's Avatar
You shouldn't worry about the actual #s. Me and a buddy got about 240 in all four with our GSRs; it doesn't necessarily mean we were pushing more air than you, it was probably the gauge.
You dont want large variation between the numbers though. Within 10% in all 4 is pretty good.
Old Oct 1, 2002 | 04:44 PM
3rdGteg's Avatar
Default Re: Did a compression test #'s a little low? (Lee Chun)
Those are great numbers; The manual says it should be like between 130 or something all the way up to 200=normal reading. The variation is what's important but 180-185 is cool; the manual says shouldn't vary no more than 25 psi
Old Oct 1, 2002 | 05:39 PM
Default Re: Did a compression test #'s a little low? (3rdGteg)
oh ok i feel better
Old Oct 1, 2002 | 06:07 PM
Razor's Avatar
but what makes me confused is how did his friends prelude get a 205 reading(10:1 compression h22a or something like that) and he got 180 on his 10.4:1 compression b18c5)??
Old Oct 2, 2002 | 03:42 PM
3rdGteg's Avatar
Default Re: Did a compression test #'s a little low? (Razor)
Possibly alot more carbon buildup the cc (in his friend's car). Carbon raises compression.
Old Oct 3, 2002 | 10:55 AM
Bseries's Avatar
your numbers aren't bad. numbers should be at least within 10% of each other. as for going turbo . be aware that boosting will eventually wear the rings down but that's the trade off. stock motors are good but weren't built for forced induction.
Old Oct 3, 2002 | 10:59 AM
Audi A4's Avatar
Default Re: Did a compression test #'s a little low? (Bseries)
there consistent.... mine were 150 115 65 55
that was after me being greedy with boost.
Old Oct 3, 2002 | 10:28 PM
Default Re: Did a compression test #'s a little low? (DRAG lll INTEGRA)
ahhh sucks man...what did u turn it up 2?
Old Oct 15, 2002 | 07:04 PM
Did a wet test and my compression jumped up to 210 psi. Does that mean I have worn piston rings?
Old Oct 15, 2002 | 07:22 PM
The_Oz's Avatar
Your numbers are showing roughly 9.0:1 - 9.25:1 respectively. Normally, I'd say it's fairly bad, but you do have a turbo in there after all, do you not? If so, did you lower your compression ratio?
Regards,
Oz
Old Oct 15, 2002 | 07:33 PM
Default Re: Did a compression test #'s a little low? (The_Oz)
yea i lowered my compression recently with thicker headgasket (compression should be around 9.0:1 now) and the numbers went down to 168-175 across the board. When I poured some oil into the cylinder, compession jumped up to 210 in all of them except cylinder one which went up to 190. Car runs fine, but I'm just wondering if my piston rings are worn and if I need to replace them.
[Modified by NHB Fighter, 8:35 PM 10/15/2002]
Old Oct 16, 2002 | 11:46 AM
The_Oz's Avatar
First you're saying it was 180-185, now you're saying it's 168-175. So, what is it exactly?
Regards,
Oz
Old Oct 18, 2002 | 01:40 PM
3rdGteg's Avatar
Regards,
Oz
You cannot tell what his dynamic compression is with static compression numbers . You can have 120psi in all four cylinders and his CR can still be 12:1.
Old Oct 18, 2002 | 01:50 PM
The_Oz's Avatar
http://www.pumaracing.co.uk/comp.htm
Regards,
Oz
Old Oct 18, 2002 | 03:26 PM
yea its 168-175 now with the 3mm head gasket. But when I first started this thread, my engine was still stock and it was 180-185.
Old Oct 19, 2002 | 10:05 PM
The_Oz's Avatar
Is the 3mm thicker therefore lowering the compression? In any case, how much thicker or thinner is it (compared to the stock gasket)?
Regards,
Oz
cryingsuns
Jul 28, 2013 10:21 AM
Junkie
Mar 22, 2008 12:21 PM
climb_on
Jul 29, 2007 03:40 PM
Blazeone
Feb 17, 2005 03:18 PM
gsr~hatch
Apr 17, 2003 03:19 PM
