Compression question
Old Feb 14, 2005 | 02:04 PM
Blazeone's Avatar
Default Compression question
Hey i just did a compression test on my motor, and got 150-150-150-150... The numbers are dead consistent.
Is this alright? The car has about 30 000 miles on it and heard that you gain compression after time becuase of carbon buildup?
Old Feb 14, 2005 | 02:06 PM
Ferrell's Avatar
Default Re: Compression question (0097ITR)
numbers seem low....
Old Feb 14, 2005 | 02:07 PM
ZygSpeed's Avatar
On one hand they seem low, but on the other they are consistent and the low numbers were probably just because you could have used a few more "cranks" to up the numbers (and/or the throttle wasn't held open).
Old Feb 14, 2005 | 02:12 PM
drdisco69's Avatar
Default Re: Compression question (zygspeed)
As long as they are consistant, it should be ok. Some gauges don't read right, but 150 all across is nice.
P.S., I'll have a compression test treat for everyone in the next few days...
Old Feb 14, 2005 | 03:41 PM
Blazeone's Avatar
Default Re: Compression question (drdisco69)
Ok i redid it again.
I let the engine warm up a bit longer, WOT, took off the intake, and i got 165 across the board. Maybe the piston rings arent fully seated yet. It burns no oil and runs great and fast, just wondering.
I am also using a "GRIP (grand rapids industrial products)" compression tester, maybe its too shitty to get a good reading.
Old Feb 14, 2005 | 03:48 PM
MattD@Stoptech's Avatar
how many times did j00 crank it?
Old Feb 14, 2005 | 04:51 PM
Blazeone's Avatar
Default Re: Compression question (El Pollo Diablo)
enough, about 10 seconds according to helms..
The engine has one compression stroke every 4 cranks, so 8 cranks would be sufficient.(two compression strokes)
Old Feb 14, 2005 | 06:58 PM
Bbasso's Avatar
http://www.c-speedracing.com/h...t.php
Old Feb 14, 2005 | 10:47 PM
Seedc2's Avatar
Default Re: Compression question (Bbasso)
thats the same tester I have ^^
Old Feb 14, 2005 | 10:56 PM
jBj's Avatar
jBj
Good info here i think, got this from user "Nameless RB26"
There isn't a 'there'. If numbers are consistent, then that's all that matters.
All low consistent numbers = bad gauge, good engine.
All high consistend numbers = good gauge, good engine.
All low inconsistent numbers = bad.
All high inconsistent numbers = bad.
That's the *general* rule I use when doing comp tests.
When it comes to actually DIAGNOSIS after a compression test.. you do a cylinder leak down.
Compression tests are not always acurate. They do not tell you what is wrong with your engine. They do nothing but give you a general *IDEA* of good/bad or ok.
When you do a compression test the engine MUST be at operating temp. Not warm. Not cold. You do it immediately following shutoff.
Throttle open.
All plugs removed.
6 or 8 cranks on each cylinder. Not 6 here, 8 there. The same on each cylinder.
Dry compression tests are worthless and usually innacurate.
I hope this info reaches people in searches.. because this topic has high frequency here.
Old Feb 15, 2005 | 02:37 AM
Jon D's Avatar
Default Re: Compression question (jBj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jBj &raquo;</TD></TR><TR><TD CLASS="quote">Good info here i think, got this from user "Nameless RB26"
Throttle open.
All plugs removed.
Nice lil write up....
Old Feb 17, 2005 | 11:32 AM
Blazeone's Avatar
Default Re: Compression question (Jon D)
Note, DO NOT use a shitty compressin tester. We redid the test with a good tester and got consistent 190's.
Old Feb 17, 2005 | 01:34 PM
drdisco69's Avatar
Default Re: Compression question (Blazeone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blazeone &raquo;</TD></TR><TR><TD CLASS="quote">consistent 190's. </TD></TR></TABLE>
What motor is this? Cams, compression, etc?
Old Feb 17, 2005 | 03:18 PM
totsie7944's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blazeone &raquo;</TD></TR><TR><TD CLASS="quote">Note, DO NOT use a shitty compressin tester. We redid the test with a good tester and got consistent 190's. </TD></TR></TABLE>
thats more like it.
88 civic
Apr 5, 2009 03:21 PM
Hondizzle!
Sep 13, 2005 09:13 AM
Nisif
Apr 12, 2005 09:13 AM
98cwtypeR
Jun 4, 2003 10:29 PM
MechEng
Feb 11, 2002 06:15 PM
