b16 idle
Old May 30, 2011 | 09:24 AM
bpoweredeg6's Avatar
Default b16 idle
I have a b16 in my eg coupe and sometimes when i apply the brake to stop and push the clutch in, the volts drop and it idles really low. I dont know how it doesnt turn off. Any ideas. Im thinking maybe alternator belt or alternator.
Old May 30, 2011 | 09:29 AM
Former User's Avatar
Default Re: b16 idle
Sounds like you may have a low idle problem.
Old May 30, 2011 | 12:44 PM
civic-steve-94's Avatar
no one ever posts if there check engine light is on so is your check engine light on
Old May 30, 2011 | 01:11 PM
no check engine light, and it doesnt do it all the time
Old May 30, 2011 | 01:41 PM
Does the CEL work?
Old May 30, 2011 | 01:47 PM
yes it works, it only drops when i stop and its only sometimes, when i start going again, the volts pick back up and everything is fine
Old May 30, 2011 | 01:48 PM
Have you cleaned the IACV? Have you replaced the PCV valve? Have you tried to adjust the idle speed?
Old May 30, 2011 | 02:25 PM
also check for vacuum leaks and when mine had a similar problem it was the tps sensor out of calibration
Old May 31, 2011 | 12:53 PM
WideBodyFEELZ's Avatar
Okay...I'm having a similar problem. I've been trying to solve it for a while now. I have a b16a in a 98 civic hatch. My CEL came on for the IACV (14), which I replaced (brand new).
The CEL came back on the other day and my car is still having idling issues and when I sit at a stop light, the idle drops down to about 100 but the car doesn't die. It also sputters when driving at a sustained speed, like on the freeway. The code is still 14 which doesn't make sense because the IACV is brand new.
Any ideas?? Any help is greatly appreciated. I've been dealing with this problem on and off for a while now and it's driving me crazy.
pfsmith99
Oct 7, 2012 02:40 PM
ThaBread
34
Oct 23, 2008 02:58 PM
importtuner07
Sep 3, 2006 04:44 PM
yoshio006
Dec 17, 2002 06:18 PM
