JDM B16 surged then acted like it didnt want to get out of its own way
Old May 28, 2011 | 01:40 PM
NOTUNINGNONADA's Avatar
Icon6 JDM B16 surged then acted like it didnt want to get out of its own way
ok this happened to me last night i dont know what caused it all i know i was driving the engine surged a bit then the car acted like it didnt want to get out of its own way. i will put a list of stuff i have done so far:
PLATFORM:jdm b16 in a 4 door ex-a civic with a chipped p28 and nology wires
things done:
checked plugs
checked fast idle vale(the thing under the throttle)
checked idle valve (behind throttle body)
changed distributor cap
checked injectors to see if one does not work
checked for vac leaks
checked starter
checked firing order
is there anything else that come to mind that i am missing??
********UPDATE***************
I noticed inside of my ecu the right side (big plug in) is corroded inside...being that im in arkansas there are not alot of tuners here so imma probably gonna start there to see is maybe if thats my problem...
Old May 28, 2011 | 01:48 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: CIVIC SOUNDS LIKE A SUBARU..WTF
Getting spark at all 4 plugs?
Old May 28, 2011 | 02:06 PM
yup...i think it might be the computer cause its pretty jacked up lookin
Old May 28, 2011 | 02:23 PM
27 VIEWS AND ONE POST COME ON YAL!!
Old May 28, 2011 | 02:42 PM
apexi_rsx's Avatar
compression test the motor... usally they sound like this when its only running on 3 cylinders
Old May 28, 2011 | 04:46 PM
NVturbo's Avatar
O.G. triple O.G.
Rust on the ecu.....is this a flood vehicle? If not, the ecu may have been left outside in the elements...mainly rain. If it wasn't a chipped ecu, I would say try another to test it out. Of course, not everyone is going to have an extra P30 ecu laying around you can borrow for usage.
Old May 28, 2011 | 05:33 PM
Libertariat's Avatar
Ek Forever y0!
Cry me a river.
All four cylinders getting spark and fuel?
Exhaust leaks? Look for black spots along your header and your b pipe where leaks are commonly found.
Old May 28, 2011 | 06:20 PM
grumblemarc's Avatar
The Grumpiest
Wife's hatch is doing that right now but it's severely misfiring.
Old May 28, 2011 | 06:23 PM
Deetz's Avatar
Crazy Honda Guy
check your distributor rotor
Old May 28, 2011 | 06:27 PM
vitamin_c95's Avatar
mine did this. I had a bad plug wire
Old May 28, 2011 | 06:44 PM
it spins im going to go put the clear cap back on now that it has gotten dark to see if it is firing on all cylinders
i dont have any pops..i just sound like a wrx..which cool..but kinda sux
Originally Posted by ek forever guy
Cry me a river.
will do that in morning
if i was in florida
wont be until mon or tues til i find that out...
Old May 29, 2011 | 06:47 AM
NVturbo's Avatar
O.G. triple O.G.
^^^ it's one of the plug wires. I had MSD plug wires before and one of them messed up. If the car can't go pass 35mph....that's the culprit because you are running on 3 cylinders.
Old May 29, 2011 | 07:04 AM
im gonna look into this....but like i said before i think this is the problem or part of..
Old May 29, 2011 | 08:52 AM
MR.johnson's Avatar
pic is way too small. get some ngk wires.
Old May 29, 2011 | 11:49 AM
Former User's Avatar
Default Re: JDM B16 surged then acted like it didnt want to get out of its own way
Part of the problem with this thread is your sparse description of the problem. "Sounds like a Subaru" and "didn't want to get out of its own way" don't say very much.
Is the engine misfiring or is it just experiencing a loss of power? Any CEL codes? If it's just a power loss, check for clogged cat, if you have one.
impaktem1boy
46
May 21, 2008 09:15 PM
allmotor2.1
Nov 30, 2007 09:14 AM
bustah49
Sep 23, 2007 06:59 AM
1PT-SICK
Mar 30, 2006 06:08 PM
highrevnef
Aug 3, 2005 09:16 AM
