JDM B16 surged then acted like it didnt want to get out of its own way
ok this happened to me last night i dont know what caused it all i know i was driving the engine surged a bit then the car acted like it didnt want to get out of its own way. i will put a list of stuff i have done so far:
PLATFORM:jdm b16 in a 4 door ex-a civic with a chipped p28 and nology wires things done: checked plugs checked fast idle vale(the thing under the throttle) checked idle valve (behind throttle body) changed distributor cap checked injectors to see if one does not work checked for vac leaks checked starter checked firing order is there anything else that come to mind that i am missing??:scared: ********UPDATE*************** I noticed inside of my ecu the right side (big plug in) is corroded inside...being that im in arkansas there are not alot of tuners here so imma probably gonna start there to see is maybe if thats my problem...:thumbup: |
Re: CIVIC SOUNDS LIKE A SUBARU..WTF
Getting spark at all 4 plugs?
Originally Posted by mcvtec
(Post 45360031)
27 VIEWS AND ONE POST COME ON YAL!!
compression test the motor... usally they sound like this when its only running on 3 cylinders
Rust on the ecu.....is this a flood vehicle? If not, the ecu may have been left outside in the elements...mainly rain. If it wasn't a chipped ecu, I would say try another to test it out. Of course, not everyone is going to have an extra P30 ecu laying around you can borrow for usage.
Originally Posted by NOTUNINGNONADA
(Post 45360158)
All four cylinders getting spark and fuel? Exhaust leaks? Look for black spots along your header and your b pipe where leaks are commonly found. |
Wife's hatch is doing that right now but it's severely misfiring.
check your distributor rotor
mine did this. I had a bad plug wire
Originally Posted by Deetz
(Post 45361071)
Originally Posted by grumblemarc
(Post 45361061)
Originally Posted by ek forever guy
(Post 45360888)
Cry me a river.
Originally Posted by NVturbo
(Post 45360702)
Originally Posted by vitamin_c95
(Post 45361085)
^^^ it's one of the plug wires. I had MSD plug wires before and one of them messed up. If the car can't go pass 35mph....that's the culprit because you are running on 3 cylinders.
im gonna look into this....but like i said before i think this is the problem or part of..
http://i107.photobucket.com/albums/m..._3722468_s.jpg |
pic is way too small. get some ngk wires.
Re: JDM B16 surged then acted like it didnt want to get out of its own way
Part of the problem with this thread is your sparse description of the problem. "Sounds like a Subaru" and "didn't want to get out of its own way" don't say very much.
Is the engine misfiring or is it just experiencing a loss of power? Any CEL codes? If it's just a power loss, check for clogged cat, if you have one. |
