stage 3 all motor cams with turbo
rebuilding my motor and was thinkin bout goin with the stage 3 bc all motor cams with a pte 6262.. i was wanting to know if anyone here has done it..or yall opinions..
here is a vido of a similar set up
http://www.youtube.com/watch?v=uBg2Q8OAwxA
Well if you are running a 6262 Im assuming your power goal is going to have to be greater than 500. Otherwise the turbo will not be effecient. Also as Th3pwn3r said, your cam choice will be depending on where you want your powerband. Skunk2 Pro1's would be a good choice for that size turbo if you want a power band higher up in the rpms. For a nice midrange powerband, ITR or Skunk2 tuner 1's would be great.
i have a dilemma like this i am putting together a b17 for a buddy of mine and at the last minuet we figured out we had the wrong cams for his build. they turned up to be a jun stage 3 cam. i was wondering whether anyone has used a cam with 304 degrees of duration and 12'' lift?
http://www.junauto.co.jp/products/camshaft/b16.en.html
Ill be the test dummy here, because I just so happen to have stage 3 bc na cams and a fully built gsr with a 60-1 garret on it. Within a week or so ill post up dyno sheets here. I'll go ahead and say the duration on the intake cam is too long and lift on the ex cam is too high for a turbo set up... But ill get back to you next week.
That's what I was getting at with the lift and duration. But I'm still curious what those cams will do compared to gsr cams, before I put them in another build anyway...figured he asked, and I have, so ill share.
175Shot4Door
Feb 11, 2009 08:55 AM
Power Rev Racing
Jan 18, 2005 08:26 PM
