stage 2 cams?
Old Oct 21, 2009 | 12:04 PM
1cammerjammer's Avatar
Default stage 2 cams?
i have satge 2 skunk2 cams in my ls-v turbo
i was told tht those cams r two big 4 turbo tht it would blow my motor
is this true would they blow my motor? would it run better on stock cams??
Old Oct 21, 2009 | 12:08 PM
komat's Avatar
Default Re: stage 2 cams?
no it wont blow
yes better then stock
Old Oct 21, 2009 | 02:19 PM
PeakBoostSi's Avatar
You will be fine i ran Pro 1's for 20k miles and no problems.
Old Oct 21, 2009 | 04:14 PM
TheShodan's Avatar
Moderator
That depends on which turbo he's using. Pro 1s work best with LARGER framed turbos 61mm and above. Otherwise, there's no realy point.
Old Oct 21, 2009 | 05:54 PM
slvrlude's Avatar
pro 1's a great for turbo, as well as type r's....stage 2 are more for n/a with the lift and duration they have and are too aggressive. the vtec crossover would probably be non existant. its not like you'll blow your motor or anything, but in my opinion, you wont get the most out of the tune
Old Oct 21, 2009 | 09:40 PM
Thanks a lot 4 the inputs I really appreciate it. It was a big help
Old Oct 22, 2009 | 12:00 AM
95skunkedgsr's Avatar
i thought there was a thread where a guy whet to stage 2's over typer's and jumped 50whp
Old Oct 22, 2009 | 05:41 PM
DA TeG 90's Avatar
Get some Blox Type B's.
Old Oct 22, 2009 | 06:50 PM
swapit's Avatar
I run the skunk2 tuner 2 cams and made almost 60hp more then type r cams on the same boost..T/3 T67 turbo
Old Oct 26, 2009 | 05:17 AM
MadHead's Avatar
I have some Skunk2 tuner 2 cams as well & I will be running a Skunk2 Pro series intake manifold, 550cc injectors, a custom ramhorn mani, 9:1 CR pistons, water-methanol injection, a Garrett t3 60-1 turbo with stage 3 backwheel & I have been told that the tuner 2's will not be ideal also. So now I'm stuck with my tuner 2's. I was told to get Skunk2 tuner 1 camshafts or ITR/CTR camshafts
Old Oct 26, 2009 | 05:49 AM
fmfkid250's Avatar
I have skunk pro 2's in my car. I am also running a large turbo though. they work alot better then stock.
Old Oct 26, 2009 | 07:18 AM
k_civic's Avatar
Im using this cams and no problem yet
hamma-head
Jun 15, 2012 03:33 PM
175Shot4Door
Feb 11, 2009 08:55 AM
integranator
Nov 3, 2007 02:31 PM
Clone
Jan 2, 2005 08:52 AM
slixxracing
Feb 2, 2004 12:19 PM
