Replaced drums and now parking brake's not working.
Old May 17, 2011 | 07:05 PM
all_conference's Avatar
Default Replaced drums and now parking brake's not working.
94 civic vx
Just recently replaced both my rear drums the whole kite and my parking brake isn't working anymore. I read about reversing and pulling your parking brake and that should adjust the parking brake? Any other stuff I should look at? I adjusted the handle to where its around 7-8 clicks when before i did my brakes, it was really high up.
Old May 18, 2011 | 06:27 PM
Default Re: Replaced drums and now parking brake's not working.
When i got done replacing the drum brake, my parking brake handle had no slack until i adjusted the handle but now, it doesn't even catch anymore!
Did the reverse thing and nothing happened. I'm stumped!
Old May 18, 2011 | 07:02 PM
shamrokk77's Avatar
you probably need to adjust your shoes. more than likely your back brakes are not working at all. or maybe you didnt reconnect your parking brake cable
Old May 19, 2011 | 05:36 AM
Jockone's Avatar
^^This^^
Sounds like you need to adjust the shoes,the auto adjusters might not be working and you will have to adjust the shoes manually and see if you can find the problem with the auto set-up.
Old May 19, 2011 | 01:31 PM
Moog_enep3's Avatar
im having the same problem. i pulled the drums off and had my friend pull the lever, and it expanded like normal, but it doesn't catch.
Old May 19, 2011 | 04:58 PM
eh9deux's Avatar
You sure you put the parking brake lever in the drums back on right? It's easy to put it on backwards if you're not paying attention...well at least thats what happened to me. haha.
Old Sep 12, 2012 | 04:53 PM
Same here too.
Old Sep 27, 2012 | 02:00 PM
This is the passenger side. Double triple checked that "clevis a" is making contact and seated correctly against the brake shoe and parking brake lever, but when the parking brake is pulled, nothing happens.
Driver side is okay cause I can actually see the brake shoe move outwards when the parking brake is pulled, but not for the passenger side. I'm so stumped now and not looking forward to having to take this to a shop......
Old Sep 27, 2012 | 05:15 PM
redm3turbo's Avatar
inspect your clevis.... easy to put them on wrong
Old Oct 1, 2012 | 12:12 PM
it's on exactly like the working driver side
Old Oct 4, 2012 | 10:09 PM
SnickterP's Avatar
10 Year Member
I have a similar problem with mine as well. Brake does not do anything noticeable when its pulled, kind of annoying
charlieboy88
Jan 4, 2013 07:58 AM
theineffable
Honda Civic (2001 - 2005)
Jul 10, 2011 11:23 AM
Lo-Buck EF
11
Aug 31, 2004 04:37 PM
AgentJam
11
Oct 15, 2003 05:50 PM
mickey513
Oct 2, 2003 04:35 AM
