deka siemens 630 cc and Neptune
Old May 14, 2011 | 01:09 PM
mar778c's Avatar
Community Builder
Community Influencer
Default deka siemens 630 cc and Neptune
Has anyone used the deka siemens 630 cc injectors with Neptune?
Old May 16, 2011 | 03:43 AM
Furyof4's Avatar
Default Re: deka siemens 630 cc and Neptune
I think we're on own here buddy.
Old May 16, 2011 | 05:25 AM
mtber's Avatar
What exact question do you have ?
Old May 16, 2011 | 08:05 AM
Furyof4's Avatar
Basically, we tried using the given offsets for them with no luck. Messed with it for a good while on sat and nothing seemed to work. We are just looking to see if someone has used them on a Honda ecu based system.
Here are the injectors.
http://www.bmotorsports.com/shop/pro...roducts_id/608
Spec sheet.
http://siemensdeka.com/specsheets/FI114961cs.jpg
Old May 16, 2011 | 08:57 AM
mar778c's Avatar
Community Builder
We were able to get it running but they are not a drop in injector. Just looking for some insite for other tuners about fuel mapping on start-up, etc.
The situation is currently using 345 prelude injectors and switch to the 630's. Mostly likely, our tuner will be able to get them to work but if others have knowledge to share it would help our cause.
Old May 16, 2011 | 10:42 AM
mtber's Avatar
Your tuner should be able to figure it out....
Old May 16, 2011 | 01:02 PM
mar778c's Avatar
Community Builder
Thanks for the insite
Old May 16, 2011 | 05:11 PM
mtber's Avatar
FYI you don't just enter the new injector size & fuel injector offsets & expect the car's tune to be spot on. You will likely have to adjust the overall fuel trim to even get close.
There after you may need to change the fuel tables due to the injector having a different spray pattern and nossle design etc.
H22AFerio
Feb 21, 2024 03:40 AM
HondaKid936
Nov 13, 2008 07:16 AM
Charlie Moua
Oct 6, 2003 06:22 PM
95c1v1cs1
Feb 10, 2003 07:09 AM
