mini me swap help
Old May 9, 2011 | 05:12 PM
turbotegy10's Avatar
Default mini me swap help
my friend and i have completed the mini me swap on his eg hatch. and we cant seem to get it to start up. we know its something to do with the dizzy he is running the z6 head and dizzy. not sure why its fighting us. what is the proper firing order for the dizzy. No matter what way you turn the dizzy just wont start.
Old May 9, 2011 | 05:45 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: mini me swap help
Got spark? Fuel? Checked firing order?
Old May 10, 2011 | 02:02 AM
Have fuel and.spark not sure if firing order is.correct
Old May 10, 2011 | 03:01 AM
grumblemarc's Avatar
The Grumpiest
WTF Wax? How do you even ATTEMPT a swap like this and not even know how to set the correct firing order? Do you at LEAST have a manual? Do a quick search?
Old May 10, 2011 | 05:51 AM
Former User's Avatar
If the plug wire firing order is correct, check the mechanical timing.
Any CEL codes? Did you swap any sensor connectors?
Old May 11, 2011 | 05:31 AM
That's the firing order we used no codes and.we didn't swap any sensors. I will check the.mechanical timing
Old May 11, 2011 | 05:45 AM
The Grumpiest
Thermostat ground?
Old May 11, 2011 | 06:02 AM
Originally Posted by grumblemarc
Thermostat ground?
He has spark and fuel.
Old May 13, 2011 | 06:37 AM
Does anyone know if y8 spark plug wires will work with a z6 dizzy. i know when you read most of the swap forums for this they tell you to use z6 wires with z6 dizzy. but since the y8 wires are for a vtec head does it matter.
Old May 13, 2011 | 06:53 AM
Problem sovled. Turns out we have to use the original dizzy and notch it. the ecu cant recognize the z6 dizzy because tooth count is different. you could replace the ecu to match the dizzy, but since we dont have that ecu we are going to notch the dizzy instead.
heyitzspikey
16
Jan 16, 2009 06:38 PM
sillyme77
Jun 20, 2006 04:24 PM
bluegen2
Oct 26, 2003 01:05 PM
rainforest
Apr 20, 2002 12:50 PM
[626]95-GSR
Feb 14, 2002 03:11 PM
