No power coming from +12v switched source or cigarette lighter pwr wire
Old Sep 29, 2002 | 12:35 PM
a1-bb1's Avatar
Default No power coming from +12v switched source or cigarette lighter pwr wire
Ok, so I removed the radio a few weeks ago, and decided to install my a/f gauge yesterday. To make a long story short, its wired to the yellow/red +12v wire and the gauge doesnt work... I measured the current and whether the key is on or not, multimeter registers at 0v. Could this be beacuse I removed the radio??? Please help
Please see my other post for more details..
https://honda-tech.com/zerothread?id=292352
Old Sep 29, 2002 | 03:57 PM
Jokr112's Avatar
Default Re: No power coming from +12v switched source or cigarette lighter pwr wire (a1-bb1)
im not sure i'm getting what your saying but the red wire is your switched volts and the yellow is constant if you got them both together than its probably crossing something out...on the other hand you might want to just check all the fuses including the one under the hood thats the one that gets everyone...check the fuse box in the hood its a 15 amp fuse if i'm not mistaking....that one blows sometimes
Old Sep 29, 2002 | 05:56 PM
a1-bb1's Avatar
Default Re: No power coming from +12v switched source or cigarette lighter pwr wire (Jokr112)
sorry i mean I wired the + from the red wire with yellow stripe, and Ive checked the fuse under the hood, its ok, and its a 10 amp. clock/radio are on the same fuse and the clock works.. this is why its pissing me off so much.
Old Sep 29, 2002 | 06:19 PM
Jokr112's Avatar
well that wire should be live rather or not a deck is hooked up to the wiring harness or not...my next suggestion is use a fluke meter or a continuity tester to see if there is any power coming from that wire at all and then my next suggestion after that is to find another wire to tap into for u'r A/F ratio gauge
Old Sep 29, 2002 | 07:52 PM
a1-bb1's Avatar
Umm i tested the wire with a multimeter thats all I had..it registered 0v but the clock, as I said before, was working.
Sorry, but I dont know what a fluke meter or continuity tester is. I probably should find another place to get my power from. What's a good place to do that? I wouldnt be asking but I dont have a Helms yet.
Also, does anybody know what's labeled 'signal power' in the diagram below for my ecu? Would that be +12v switched?
[Modified by a1-bb1, 4:53 AM 9/30/2002]
Old Sep 29, 2002 | 08:16 PM
Jokr112's Avatar
Don't tap into your ecu man thats not fun if u mess it up the only thing u should tap into your ecu is the wire u need to get the reading for a/f gauge...just run a wire directly to the in car fuse box to the radio fuse pull the fuse out either wrap the bare wire around one of the teeth of the fuse or use a fuse connecter from radio shack <too much work for me, when u can just wrap the wire around the tooth of the fuse and put it back in> and then you'll have the power u need when the car is on...also make sure u got a GOOD ground thats sometimes a serious problem easily overlooked
Old Sep 29, 2002 | 08:59 PM
a1-bb1's Avatar
argghh the ******* incar fuse box.! shouldve checked there first.. it was a 10A acc fuse that was blown...
Fixed and working properly now!
Old Sep 29, 2002 | 09:24 PM
Jokr112's Avatar
Didn't i say to check all fuses INCLUDING the one in the engine bay...which also means the one in car on you well atleast you got it done
Haha i also noticed your avatar is the same pic i have as my wallpaper on my computer lol
[Modified by Jokr112, 10:25 PM 9/29/2002]
Tyler Harteau
Oct 18, 2018 09:19 AM
vtak2nr
Audio / Security / Video
Sep 8, 2011 08:02 PM
efjones9
Jun 10, 2009 08:33 AM
MrBryan
May 28, 2007 04:27 AM
KrispyKreme
12
Mar 17, 2005 01:13 PM
