Please Help! B16 Turbo spits and sputters at anything over 1/4 throttle at 7 psi
Old Sep 29, 2002 | 11:58 AM
SiR Kid's Avatar
New User
Default Please Help! B16 Turbo spits and sputters at anything over 1/4 throttle at 7 psi
Ok, we've been playing with my car on the Wideband since I got it back on the road.
We were getting the WOT to about 11.0:1 fuel to play around with timing, and see what the car likes, on the safe edge of performance.
So far, with 2 range colder NGK's, a Blaster coil, and LOTS of playtime on the laptop, we've got the a/f ratio to about 11.5:1, but as soon as the car makes boost at WOT it spits and sputters and doesn't GOOOO!
Anyway, we've played with timing til we were blue in the face, and haven't found the key yet. Anyone else run into this wall while tuning their car?
Car runs great in boost at 1/4 throttle BTW, but as soon as you try to step on the accelerator to make it go faster, it just spits and sputters at anything over 4 grand
Hint Hint, maybe?
Old Sep 29, 2002 | 12:36 PM
PrecisionH23a's Avatar
Default Re: Please Help! B16 Turbo spits and sputters at anything over 1/4 throttle at 7 psi (SiR Kid)
what did you gap your plugs at?
Old Sep 29, 2002 | 01:29 PM
Boost2NA's Avatar
Default Re: Please Help! B16 Turbo spits and sputters at anything over 1/4 throttle at 7 psi (GudeH23a)
I had that same problem, my plugs were gapped to big. Try closing the gap and it should fix your problem
Old Sep 29, 2002 | 04:53 PM
BoostedH23a1's Avatar
Default Re: Please Help! B16 Turbo spits and sputters at anything over 1/4 throttle at 7 psi (Boosted99Si)
in other news get missing link if u dont have one. fish tank check valves blow.
Old Sep 29, 2002 | 06:14 PM
BlueSi2k's Avatar
Default Re: Please Help! B16 Turbo spits and sputters at anything over 1/4 throttle at 7 psi (BoostedH23a1)
hes got a standalone
Old Sep 29, 2002 | 08:54 PM
SiR Kid's Avatar
New User
Default Re: Please Help! B16 Turbo spits and sputters at anything over 1/4 throttle at 7 psi (BlueSi2k)
Plugs are at .033, acted the same at .050, stock setting...
Old Sep 30, 2002 | 08:34 AM
SiR Kid's Avatar
New User
^^ up
Old Sep 30, 2002 | 08:40 AM
madman604's Avatar
whats your fuel pressure at? high flow pump? injectors?
Old Sep 30, 2002 | 08:52 AM
hybrid901's Avatar
Default Re: Please Help! B16 Turbo spits and sputters at anything over 1/4 throttle at 7 psi (Turbo E)
Jody try gapping them down to like 26 just to see if that helps.
Old Sep 30, 2002 | 09:49 AM
SiR Kid's Avatar
New User
Default Re: Please Help! B16 Turbo spits and sputters at anything over 1/4 throttle at 7 psi (hybrid901)
Got a Holley replacement pump for a DSM, got 550cc injectors, running stock fuel pressure, but the wideband says the car is at an extremely safe 11.0 til we get this resolved.
Josh, I'll go by my storage unit today and try gapping them down a little more. that small of a spark shouldn't be bad since I installed the Coil, so hopefully it'll still light off like a champ
Old Oct 1, 2002 | 05:40 AM
craesq's Avatar
Are you getting a check light? If your MAP reads boost, then the car will go into limp mode (i.e. over-rich = sputters and drives like total crap). Get a missing link or add more check valves.
Old Oct 1, 2002 | 06:32 AM
GraphiteAccord's Avatar
Default Re: Please Help! B16 Turbo spits and sputters at anything over 1/4 throttle at 7 psi (craesq)
news flash noob. don't need ethier with a standalone.
Old Oct 1, 2002 | 08:22 AM
hybrid901's Avatar
Default Re: Please Help! B16 Turbo spits and sputters at anything over 1/4 throttle at 7 psi (GraphiteAccord
Jody have you regapped the plugs? A customer at work was having the same problem with a supercharged 5.0 and I regapped the plugs down to .028 and problem was solved.
[Modified by hybrid901, 5:23 PM 10/1/2002]
Old Oct 1, 2002 | 08:35 AM
Speedworks801's Avatar
Agreed on gapping the plugs to .026 or .023, Also maybe pull a little fuel out of it, try 12:5 ish or at least 12:1ish. At this boost level, you could go 13.5's. What stand-alone? How did you "play with timing"?
[Modified by Speedworks801, 11:47 AM 10/1/2002]
Old Oct 1, 2002 | 09:05 AM
gapping to .023-.026 is a little too close, .028-.029 is what most dyno tuners recommend.
Old Oct 4, 2002 | 04:51 PM
SiR Kid's Avatar
New User
Ohhhh k. Here's what's going on now.
We left the plugs gapped at about .033, and we added some timing wince the fuel is good. Wideband says 11.8:1 to 12.2:1 all the way through the revs.
Here's what's freaking me out BADLY. We're running STOCKish timing up to 7psi, and the car is loving it. No signs of detonation, no nothing. The car 90% of the time doesn't spit and sputter like it did, but we're scared to increase timing any more than it is. It's at 28.8 degrees total timing at 7psi on 93 Octane. Someone tell me something else is going on, cause me and my tuner are wracking our brains trying to figure out why the car needs so much freaking timing...
Old Oct 4, 2002 | 06:50 PM
SGR Teg's Avatar
my car was the same way. around 4 grand when you floor it it doesn't wanna go. i was at the dyno and none of us knew what was wrong. i talked to my other friend and we tried advancing the timing and it worked. no detonation runs good up to redline no more sputtering. i've checked my plugs and they all look good. i'm running 91 octane at 8psi.
Old Oct 4, 2002 | 11:06 PM
SiR Kid's Avatar
New User
Anyone else have experience with having to feed the car timing to keep away sputtering gremlins while facing impending detonation and ultimate engine doom?!
Old Oct 5, 2002 | 12:09 PM
SiR Kid's Avatar
New User
Someobdy's gotta know... Could my cam timing be off?
Old Oct 5, 2002 | 12:44 PM
Mr. Softee's Avatar
maybe your cam gears are off? Maybe your head is milled rocking back hte timing?
JDM IN MY SOL
Jun 25, 2011 12:54 PM
ef dino
Aug 23, 2007 10:28 PM
adubaz7
Aug 16, 2007 06:12 AM
Yosshaa
Oct 8, 2003 10:32 PM
justinCO
Oct 29, 2002 11:40 AM
