5.5" compressor intake induction tube
My turbo has a 5.5" inlet.
I'm trying to do an induction of some sort.
I'm guessing you can not buy piping or bends this size?
Could I slice 2 3" pipes, trim, weld together and re round?
Or should I just get some alum sheet rolled that size?
Any ideas or suggestions would be great!
Thank you for your time,
DK
DK
Global tech sells 5 and 6". Also, ATP sells them too
http://www.globaltecheng.com/Product...=0&VS3=0&VS6=0
http://www.globaltecheng.com/Product...0&VS4=0&VS15=0
http://intakehoses.com/Merchant2/mer...gory_Code=SIT7
There are many options out there man.
Find a 5" or 6" filter and just buy tubing to match.
find a metric equivalent tube and stretch a 5in coupler/filter over it.
roll some sheet and pie cut as needed.
make an airbox and use a big flat filter.
welding smaller tubes together would be harder than just getting a 6in tube and taking a slice out of that and squeezing it together a little.
a little off topic, but how much of an advantage is it to channel air into the inlet vs. just open compressor inlet, say like on a top mount manifold?
I have heard of NA guys seeing positive plenum pressure doing a ram air setup.
Its worth it, but it comes at a cost.
