which size turbo?
Old Jan 5, 2003 | 11:35 AM
HuskerHybrid's Avatar
Default which size turbo?
looking to do forced induction, want to consolidate all ideas on turbo size, i don't really understand compressor maps very well, i just want a survey to see what you guys think...
i'm looking at:
-a steetable, relatively low maintenance, no internal work done, system that can still run into the 225hp range.
what do you guys suggest?
Old Jan 20, 2003 | 09:02 AM
vtec.dc2's Avatar
Default Re: which size turbo? (HuskerHybrid)
what kinda of engine is it for and how much boost?
you can calculate most of your turbo.. - for compressor -
https://honda-tech.com/zerothread?id=233598
http://www.speed-factor.com/turbosizing.zip - download link
an easy tool, then just use the data on an compressor map, its not as accurate as doing every calculation yourself, but very close, once you find out the compressor, its easy to calculate the turbine size.. IM if you need help with that..
integlspwr2k
Apr 10, 2005 10:25 PM
gsrhatch530
Nov 10, 2003 11:28 AM
Spoold_R
Sep 12, 2003 08:13 AM
X2BOARD
Mar 29, 2002 09:20 AM
