SRS delete, but to retain horn function?
Old Apr 25, 2011 | 08:22 PM
Wdpfreak145's Avatar
Default SRS delete, but to retain horn function?
Upon taking out my dash yesterday, I started contemplating where to locate my proportioning valve for the brake system when I do the tuck. I have seen several references to mount it on the shelf where the SRS computer is located. Having no use for the SRS, I've decided to go ahead and delete it. I've already depinned the cruise control from the aux harness and removed the motor and pedal cable, so that won't be a problem. All I need for that is to find the plate that takes the place of the cruise switch on the steering wheel.
How can I delete the ABS and still retain the horn functionality? I will DEFINITELY need the horn now, as it has been a safety issue in the past not having one and is required by state law for inspection. This will also help with running an aftermarket steering wheel in the future. Are theses systems modular? Would I need to replace the slip ring and such to do a full ABS delete in the end? Or is it possible to keep it with the stock wiring?Any and all help is greatly appreciated.
Old Apr 26, 2011 | 01:37 AM
First.EG's Avatar
Default Re: SRS delete, but to retain horn function?
what year and model is it man?
Old Apr 26, 2011 | 07:46 AM
Sorry, should have clarified. It's a 95 ex sedan. Eg/eh9
Old Apr 26, 2011 | 08:21 AM
delsolo95's Avatar
are you putting a quick release? there is something about that in the faq
Old Apr 26, 2011 | 08:47 AM
JDM_DC4_Fanatic's Avatar
Ummm last time i checked removing the ABS had nothing to do with the horn. wtf are you talking about dude? lol
Old Apr 26, 2011 | 09:03 AM
apexi_rsx's Avatar
lol thats what i thought. should not interfere with ur horn at all. since the car was equipped factory with an air bag system some inspections can fail u for not having it.
Old Apr 26, 2011 | 09:55 AM
If i understand correctly, the horn is integrated in the srs wiring. Hence why the wiring diagrams for horn systems between srs equipped civics and those that are not.equipped with them are different, just for starters.
Second, they can't fail me for it, so long as my abs light isn't on. No computer, no light.
Lastly, I will be running an aftermarket wheel in the future.
Old Apr 26, 2011 | 11:22 AM
apexi_rsx's Avatar
if u run into the problem and it does not work just follow this write up and goodluck.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/write-up-how-wire-up-horn-non-srs-eg-civic-1926111/
Old Apr 27, 2011 | 09:46 AM
I think I'll opt to keep it and hide the prop valve in front of it. I'm just worried about the upkeep on it and half the sensors to run the srs are faulty after 15 years anyway lol.
papi123
Honda Civic (2001 - 2005)
Apr 10, 2014 07:27 PM
j.packsb
Feb 19, 2010 06:30 AM
arinaldi
Jun 24, 2009 08:47 PM
kPRO dz
May 11, 2009 02:30 PM
