skunk 2 manifold on b16 obd 2 help
Old Apr 23, 2011 | 09:36 PM
jdmeg6honda's Avatar
Default skunk 2 manifold on b16 obd 2 help
on the stock manifold its got 3 pipe where u put the pcv and vacuum line and the other another sensor hoes on the skunk two it has only two pipes one on on front and one on back the i need help is where do that 3 hose go into??
Old Apr 24, 2011 | 08:56 AM
Sean @ ESG's Avatar
Default Re: skunk 2 manifold on b16 obd 2 help
The way you typed that out doesn't make it any easier to decipher your problem, but on the Skunk2 IM there will be a two holes you will not use. They need to be blocked off.
Old Apr 24, 2011 | 09:10 AM
if i block the two holes then where do the pcv plug up too and the other two sensor?
Old Apr 26, 2011 | 07:06 AM
stock and on the skunk 2 it has only 2 ]
Old Apr 26, 2011 | 07:21 AM
delsolo95's Avatar
PCV is the arrows. the one below that goes to other hoses that connects to the canister. i think it plugs to the purge solenoid. the one to the right connects to the brake booster.
Old Apr 26, 2011 | 09:27 AM
so nobody knows where the 3rd hoses go?
Old Apr 27, 2011 | 09:39 AM
here is the new pic of skunk 2 on the b16 wit the missing pipe i got no where to put plug the pcv
kbear
19
May 17, 2013 05:04 AM
Kelb
Aug 13, 2007 08:36 AM
91hatch_on17's
11
Mar 3, 2005 07:06 PM
tokes
Jan 25, 2004 11:32 AM
canuck-mx6
Feb 23, 2002 01:08 PM
