skunk 2 manifold on b16 obd 2 help
on the stock manifold its got 3 pipe where u put the pcv and vacuum line and the other another sensor hoes on the skunk two it has only two pipes one on on front and one on back the i need help is where do that 3 hose go into??
Re: skunk 2 manifold on b16 obd 2 help
The way you typed that out doesn't make it any easier to decipher your problem, but on the Skunk2 IM there will be a two holes you will not use. They need to be blocked off.
PCV is the arrows. the one below that goes to other hoses that connects to the canister. i think it plugs to the purge solenoid. the one to the right connects to the brake booster.
91hatch_on17's
11
03-03-2005 07:06 PM
