Transmission & Drivetrain Gearboxes, Differentials, Clutches
differential bearings
Old Apr 23, 2011 | 12:58 PM
88 EF Hatch's Avatar
Default differential bearings
Ok you guys I have a type r lsd and its going in my b16 trans and I need differential bearings, do I purchase b16 diff ball bearings? Or do I get type r ball bearings? And if I get type r, which spec? 95-98 spec or 99-01 spec? There are 2 different part #'s for those years at acura. Thanks. I looked at the 97 type r ball bearings and they looked different than the bearings that the type r lsd came in. They are thinner and width, (from bottom of bearing to top)
Old Apr 23, 2011 | 10:08 PM
MFactory's Avatar
Default Re: differential bearings
Just use the ball bearings; they are cheaper. You will need the 19.5mm bearings though, not the 18mm B16A bearings.
Also, looking at your username, if you really do have an EF, the Type-R LSD might not work, even if you change the final drive to the GSR/Type-R. The countershaft dimensions are different. I guess you could mix n match the ring gear/countershaft, but that may cause further problems down the line.
I would recommend you get a B16A fitment LSD instead, as they are a direct fit.
Old Apr 25, 2011 | 06:27 PM
no its not for my b16 its going on my 00 b16a2 usdm trans on my eg, so If i go to acura/honda off which vehicle should i order the ball bearings from to get the 19.5 mm? and not the 18mm?
Old Apr 25, 2011 | 06:37 PM
and like i said do I use the thinner ball bearing
or this one
Old Apr 25, 2011 | 07:56 PM
David @ Synchrotech's Avatar
The differential bearing style for the B18C GSR/ITR S80 transmissions split in 1998. The tranmsission with sticker ID S80-3089682 and higher use offset ball bearings OEM# 91005-P80-E31.
The earlier model S80/Y80 before S80-3089682 GSR/ITR will use tapered roller bearings OEM # 91005-P80-003
B16/B18A/B18B use the ball bearings without the offset. You can use these bearings on the ITR LSD as long as you install a 70 thous. shim under each bearing.
You will need to change the preload shim to the ball bearing design if changing from tapered roller bearings to ball bearings. Any of these bearings will work as long as they are shimmed correctly.
Silvertc
Apr 19, 2009 05:40 PM
powerneedy
Mar 21, 2008 05:39 AM
fullracegsr
Feb 12, 2006 07:44 PM
m3bluegsr
May 21, 2004 02:08 PM
KENLUDE97
Jul 25, 2002 06:21 AM
