lsd shimming
Old Mar 20, 2008 | 09:44 AM
powerneedy's Avatar
Default lsd shimming
alright i have and obx lsd and now its time to put it in. so i am ordering my bearings and new axle seals but what shims? is there a shim size that i will most likely use.
Thanks guys
Old Mar 20, 2008 | 05:00 PM
powerneedy's Avatar
come on ppl
Old Mar 21, 2008 | 05:08 AM
Runnerdown's Avatar
Default Re: lsd shimming (powerneedy)
too many variables and a lot of shims to choose from. I have found that the obx usually require thinner shims to fit them.
Old Mar 21, 2008 | 05:39 AM
dyingwish's Avatar
Default Re: lsd shimming (Runnerdown)
If you are reusing/ordering the taper-style bearings used in b16/GSR transmissions, then you will be ordering a 79.5mm shim in whatever thickness you need to obtain a .004" clearance between the bearing and the gear-housing side. Going this route will require some preload adjustment on the bearings on BOTH sides of the diff.
If you are ordering the newer enclosed bearings, then you'll be ordering an 80mm shim (Look at the ITR parts) in whatever thickness will get you that clearance. Simple, and this allows you to bypass the preloading of bearings, or the reusing of the thrust shims on either side of the stock diff.
PR8urVtec
Transmission & Drivetrain
10
Jan 29, 2016 08:19 AM
speeddave
Apr 29, 2009 11:35 PM
DaiJekBok
May 23, 2006 01:45 PM
AllMotorB
Feb 26, 2006 07:21 PM
karmannghia
Feb 4, 2003 08:25 AM
