loose shifter
Old Apr 22, 2011 | 10:00 PM
oh_dam's Avatar
Default loose shifter
i cannot figure out what could the problem be , ive replace the bushing that goes around the ball on the shifter but it stills swings side to side alot ..
Old Apr 23, 2011 | 05:42 AM
Matt93eg's Avatar
Default Re: loose shifter
The shaft that comes out of the tranny, where the Linkage slides on. Do you have a bolt slid through that with a nut on the other side? If so this will cause the shifter to be loose and flop around even when its in gear. If you have done the bolt with nut method. The cure is to do it the "right way" and use the "Spring Pin"(IE: Bitch Pin).
Old Apr 23, 2011 | 06:21 AM
219's Avatar
219
chances are no one has messed with it and it needs to be ground out and replaced with a bolt and nut, also good luck finding that bushing i had a hell of a time looking for one and had to jerry rig one up with sum washers
Old Apr 23, 2011 | 10:10 AM
EJ1civic coupe's Avatar
they make bushing kits for this problem!!!!
http://www.jhpusa.com/store/pc/viewP...idcategory=562
that will fix your problem..idk how many times i seen this damn question..the bushing you replaced wont do ****..also check the bitch pin
Old Apr 23, 2011 | 11:11 AM
Linked's Avatar
this is a different problem when you have ALOT of side to side play in the shifter
your shifter bushings can be in great shape but still have side to side play if the spring pin does not fit snug into the shaft
i have this problem too and i have my spring pin in. the only way i thought of remedying it was to boring it out to a larger diameter and using a nut/bolt like stated above
Old Apr 23, 2011 | 11:29 AM
then do so with a nut/bolt then..it will work with that method..what ever floats your boat..i had the same prob..sloppy shifter side to side movment and i bought this kit and installed it and it took the slop away..if it dont work then do so with the nut/bolt setup
Old Apr 23, 2011 | 11:32 AM
TaffetaEj6's Avatar
not too much involved w/ the shifter assembly...probably did a half *** job putting it back together. Mine had lots of play side to side and up and down. Got the basic energy poly shifter bushings from an auto-parts store and the other oem bushings that hold the shifter ball in place from honda. Both sets cheap cheap cheap, and shifting is buttery smooth. Go back thru and double check your work.
Old Apr 23, 2011 | 11:36 AM
exactly
Old Apr 24, 2011 | 07:14 PM
oh_dam's Avatar
i bought the car with this problem . im most likely gonna do both ways , since it does look like the shifter needs new bushing anyways .
Old Apr 24, 2011 | 09:32 PM
clutch6racerone's Avatar
That sucks bought it with that problem
Old Apr 27, 2011 | 10:28 AM
LoLoCivic's Avatar
its still driveable right ???
Gant
Jan 5, 2008 09:54 PM
red-teg!
Apr 11, 2007 07:27 AM
tegsp
Jun 9, 2005 12:05 PM
90Integra
Apr 25, 2005 08:47 PM
Dspad_91Civic
15
Apr 24, 2004 08:02 AM
