94 d16z6 miss
Old Apr 20, 2011 | 11:53 AM
mktaylor90's Avatar
Icon2 94 d16z6 miss
I have a 94 civic.I have replaced the tps, plugs, wires, and fuel filter. Its like a little miss and when it is cold it misses a little worse. But when I give it gas and drive it she runs fine. When I got it she was throwing two codes (tbs and fuel supply). But when I fixed tps it has no codes now. Please help thanks.
Old Apr 20, 2011 | 11:55 AM
frankenghia's Avatar
Default Re: 94 d16z6 miss
Did you calibrate the tps? Also you can clean your iacv and fitv.
Old Apr 20, 2011 | 11:56 AM
fleabag's Avatar
clean/fix ALL vehicle grounds.. check the ohms of the spark plug wires..
Old Apr 20, 2011 | 12:04 PM
99ssinoc's Avatar
As said above.... Calibrate TPS and check grounds. Also which plugs did you use? OE type? Some singles are known to act up with a/m plugs in em.. also check timing for what its worth, since its an easy task.
Old Apr 20, 2011 | 12:21 PM
mktaylor90's Avatar
ya i got the throttle body off a b18 four door teg youll dont think i have loss of compression in one of the cylinders
Old Apr 20, 2011 | 12:25 PM
mktaylor90's Avatar
plugs are ngk what she calls for
Old Apr 20, 2011 | 12:33 PM
The only way to know for sure if its compression is to just do a compression test. Its very easy.
Old Apr 20, 2011 | 12:34 PM
have you checked the tps yet? Calibration?
Circaskaterr
Mar 15, 2016 02:18 PM
SmaTTeRLegion
15
Sep 2, 2013 11:28 AM
WrongSide
Jan 4, 2009 05:34 PM
jamlude
Mar 8, 2008 08:54 AM
Kamin
Sep 15, 2002 06:42 PM
