94 d16z6 miss
94 d16z6 miss
I have a 94 civic.I have replaced the tps, plugs, wires, and fuel filter. Its like a little miss and when it is cold it misses a little worse. But when I give it gas and drive it she runs fine. When I got it she was throwing two codes (tbs and fuel supply). But when I fixed tps it has no codes now. Please help thanks.
Re: 94 d16z6 miss
As said above.... Calibrate TPS and check grounds. Also which plugs did you use? OE type? Some singles are known to act up with a/m plugs in em.. also check timing for what its worth, since its an easy task.
Circaskaterr
03-15-2016 02:18 PM
